Hello!
At first i wanted to say "It is my first big project" but i have done bigger stuff then this.
But everyone except 3 of my boards i etched and drilled myself, only 3 i had made.
And those three had a bunch of components on them but only 4 different values...
Yesterday i ordered a panel with 12 different boards (2 each, 24 total), milled, solder mask, silkscreen... all the fancy stuff.
Getting the panel right, the routing on all 12 boards, figuring out how each chip works, searching for the right parts...
In all it took me about a month, maybe more.
I printed the boards on paper, made sure the footprints were right, checked for clearence. Placed crucial components on the "printed paper boards" and dit everything to minimise the possible snafus. I am certain i missed something but that is ok.
But today i put all the parts in a sheet, checked what i had and what had to be ordered and nearly lost it... -_-
I only have to order passives, for the most part, but there is so much on these boards...
One 10Ohm resistor here, a 10pF capacitor there, another 10µF here, another two 60,4K resistors... the list goes on.
Odd values the datasheet demandet or the calculations predicted, from the start i used the same component values whenever possible.
I have to split the order between two different retailers because it would cost twice as much ordering just from one retailer.
Tomorrow i will have to face the music, i dread the moment i see the final value on the invoice.
My piggy bank will most likely be sacrificed...
