Author Topic: Getting weird ground signals with thermocouple  (Read 1490 times)
Offline diegoterc3Topic starter
  • Country: pe
« on: February 18, 2015, 06:37:43 pm »
Hello,
I am trying to make a reflow oven and have already made my first prototype for testing.
I can´t get my MAX6625 to read anything from the K type thermouple. I need help! On the datasheet it said that in order for the cold junction compensation to work the negative side of the thermocouple had to be connected to ground wich I did. When I meassure GND with an oscilloscope I get the negative thermocouple signal ofcourse. Will this make my MCU crazy?
Also I have some questions about the thermocouple wave form. Is it supposed to be this way? (see image).
Thank you!!
Online Andy Watson
Re: Getting weird ground signals with thermocouple
« Reply #1 on: February 18, 2015, 06:58:45 pm »
Cannot read ?
or can read but data is garbage?
  • Country: pe
« Reply #2 on: February 18, 2015, 07:02:59 pm »
Cannot read. I am cheking my code as well and debugging everything line by line to check if everything is ok.
  • Country: pe
« Reply #3 on: February 19, 2015, 04:24:52 pm »
All right I made it work. The thermocouple wasn't making any contact to provide the signal.
But I would still like to know the answer. Would connecting the negative side of the thermocouple affect other digital devices because of the dynamic reference (GND)?
Thank you!
