Author Topic: relay poping!!  (Read 1755 times)
Offline angelothewolfTopic starter
relay poping!!
« on: April 24, 2013, 06:50:38 pm »
hi everybody, im building an active a/b box with volume control for active studio monitors, everything is working ok until i decide to add a mute switch. so i made a little perfboard with 4 G5A-237PL Omron relays, each one is shorting each output pin to ground. the thing is that i cant get rid of the loud spike/pop when i turn the relays off.
already try the diode for the coils, etc.
there is any way to solve that issue without compromise the signal????  |O
 :scared:
Offline commongrounder
Re: relay poping!!
« Reply #1 on: April 24, 2013, 07:24:54 pm »
Do you have a way to check if there is any DC riding on your audio lines?  That would cause a pop when the relays opened (and maybe some when they close).  Otherwise the four relay coils may still have enough EMF kick together, even with the damping diodes, to induce a current in your audio lines.
vlf3
  • Guest
Re: relay poping!!
« Reply #2 on: April 24, 2013, 09:59:49 pm »
Check that the diodes are correctly placed across the relay coil !, with the ring end connected to the positive of your switched supply... if you find there the wrong way around, and are IN4148 type, replace them.
Otherwise, you could try and place a capacitor across each relay coil, a value between 1 Mfd to 47 Mfd with the diode, again positive end of the cap + to the power supply side; also place a series resistor in-line to the relay positive coil end, with a value between 10 to 22 ohms... this will depend on the relay pull-in working voltage, but is a good starting point.
If none of this helps, then it's likely the signal line inputs are at a charge level; e.g. your equipment in-out line capacitors have a DC charge, at each internal equipments blocking capacitor...  by switching this potential to ground, will then discharge the in-out cap voltage, thus your popping.
The problem might be somewhat hard to resolve; mainly because you need to bleed away the DC potential build-up to ground, before you hard switch them.  Adding a resistor on the in-put and out-put line feeds to ground, may reduce or remove the problem ?.  So when your relay switch comes-in, the caps are near to ground reference potential, instead of floating between coupling potentials; particularly if there not internally, impedance terminated.
If your studio system is based on 600 ohm impedance, then a 1K2 value should do, placed on the in and out lines, e.g. between your relay contacts equipment in and out line connections... however, if the studio is based on 47K impedance, then terminate with 82K values.
