Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Problem unidentified in project
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Problem unidentified in project (Read 601 times)
Siddhat
Regular Contributor
Country:
on:
April 28, 2019, 06:58:56 pm »
Hey everyone. I have been working on a project namely, "Obstacle Avoiding Robot". The concept is to avoid obstacles and move left or right depending upon the obstacles on right or left of the robot respectively as the name suggests. IR module is used to sense the obstacles. The logic for the task was made using K-map and the circuit seem to worked fine in software until the hardware assembly part was in turn. When the circuit was assembled the motors did not rotate with constant speed but rather rotated not as desired. I could not find out the problem. Plus I was told to use a transistor to drive the motors with constant speed to solve the problem. But I could not figure out how to use the transistor to do so as the motor driver IC has two logic outputs.
The circuit schematic is attached.
Logged
Benta
Super Contributor
Country:
Re: Problem unidentified in project
Reply #1 on:
April 28, 2019, 07:58:40 pm »
You can throw R1 and Q1 away to start.
Apart from that, it's impossible to say. The L293 is real simple, so it's up to your drive system to resolve this, and we don't see that.
Logged
OM222O
Frequent Contributor
Country:
Reply #2 on:
April 28, 2019, 08:20:55 pm »
that part allows you to drive 1A through the motors so it shouldn't be an issue ... you need to check your input signals and connections.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
