I am facing a curious problem and I can't figure out what is causing it.
I have a circuit that switches a load on a +5V rail using a TI TPS2557. The +5V supply comes from an external mains-powered switch-mode PSU. If I enable the output from the TPS2557 and load it with 5A using my DC electronic load, then turn off the load, the Power Good (PG) output signal of the PSU drops out momentarily at the point of turn-off. As in, is explicitly pulled low by the PSU, not glitching or anything like that. It stays low for about 250-ish milliseconds, then comes back again.
Schematic of the +5V load switch portion of the circuit is attached below. The PG signal (not shown below) comes in and has a 47k pull-down and a 1k series resistor before going to an MCU GPIO.
I've tried this with two different PSUs (of different brand and model), and they both exhibit the same behaviour.
At first I thought maybe there was some kind of overshoot on the +5V supply rail happening at load turn-off, and that was causing whatever kind of voltage supervision the PSU has to think it had gone out of regulation - i.e. triggering over-voltage protection (OVP). But scoping it shows nothing untoward happening. With the first PSU, the +5V rises slightly by about 150mV for around 10ms then settles to its idle level (~5.3V); the second PSU exhibits no rise. I even looked up the specifications for OVP on the kind of voltage supervisor ICs these PSUs feature, and it's minimum of 5.7V, which I am not seeing being exceeded.
I also checked the active-low enable signal to the PSU to see if it was glitching to the 'off' state, which it wasn't. I don't know how that'd be possible anyway, given it is connected to a physical slide switch pulling the enable signal hard directly to ground in the 'on' state.
One curious thing I observed is that it seemed far less likely to trip the PG if the load is turned off within about 10 seconds of turning it on.
Any suggestions as to how I can figure out why this is happening?
