Author Topic: Raspberry PI Based DAC  (Read 1293 times)
Offline electro_ptTopic starter
« on: August 27, 2016, 02:26:21 pm »
I just got a new raspberry PI 3, and have been using it as a small TV based computer.  However as is often the case, once you have flexible hardware you start looking for other things to do with it.  I have been intrigued by the high speed one can switch the GPIO pins, and thought there might be potential for a DAC.
I know there is hardware already out for this, but I was interested in learning to do it myself for the experience.  Any suggestions or recommendations.  Perhaps a R-2R?  Maybe an RC circuit on the output of a pin...a bit like Raspberry's RCA audio out but perhaps with higher dynamic range?  Custom waveforms would be ideal, perhaps with 0-20MHz range.  Just starting in this sort of thing so thought it would be a good project to learn.
Offline NiHaoMike
    • Facebook Page
Re: Raspberry PI Based DAC
« Reply #1 on: August 27, 2016, 05:47:09 pm »
Beaglebone Black can do it. It has I/O coprocessors that can easily handle 100Mhz sample rate, input or output. There's even a logic analyzer based around that.
