I try to avoid trimpots in designs wherever possible. I prefer to connect a precision resistance box, set the value to the one which gives the best performance/correct circuit parameter and solder a suitable resistor network in place. There are also ways of achieving a similar thing which chains of resistors which can be removed by cutting the track or shorting with a jumper/solder, until the circuit works properly.
