Author Topic: Project feedback - LORA + GPS chip recommendations (not LoRAWAN)  (Read 699 times)
Offline rfwifi123Topic starter
Hi all
I am developing a product for commercial use (hopefully) and wanted recommendations on some LoRA and GPS chips.  The main criterias I have are the chips must consume minimal power (a deep sleep mode is also required), be cost effective and be available in a break out such that I can experiment with them.
The system architecture will consist of a base unit which can communicate to a series of nodes, containing the LoRA tranceivers (simultaneously) and GPS chips. I am new to LoRA but like the fact that it has a range of up to 10-15km.
For the nodes, so far I have been reading up alot on the SEMTECH SX1279 LoRA tranceiver and Ublox NEO-M9N GPS.  The intent will be to use ceramic PCB mounted antennas for both chips with a PIC MCU.
For the base unit, again I will be using a PIC MCU and ceramic mounted antenna (for LoRA). Unsure of what chips to use in order to communicate with many different LoRA nodes.
For prototyping purposes, I require either DIP package chips or ones on prefab'd breakout boards.
1. Are these chips recommended for commercial use? Has anyone had any experience with them and can list any drawbacks?
2. I am finding it difficult to find the SX1279 in a breakout with a schematic diagram. Does anyone know of one?
3. The Ublox is fairly expensive at about $15 USD (even in mass production). Does anyone know of an alternative fit for commercial use? If so, do you know of a break out?
4. Which LoRA chip do you recommend for the base unit ?
Thanks
Offline profdc9
Re: Project feedback - LORA + GPS chip recommendations (not LoRAWAN)
« Reply #1 on: July 01, 2020, 03:30:39 pm »
« Last Edit: July 01, 2020, 03:41:50 pm by profdc9 »
Offline RobBarter
    • Bedrock Systems Ltd
« Reply #2 on: July 01, 2020, 03:44:57 pm »
I've gone with the Quectel L96-M33 GPS module £4.76each.   https://www.aliexpress.com/item/32970226292.html?spm=a2g0s.9042311.0.0.62844c4dePbqX4
And For Lora (although I'm using it for LoraWan) SX1262  in the module E22-900M22S (approx £5 on EBay).
Can't give you much feedback just at the moment.  Still in testing.
minimal sig so a single msg doesn't take up the entire page!
