Author Topic: Project with buried heaters  (Read 3094 times)
Offline AlexTopic starter
« on: October 23, 2013, 01:49:08 pm »
Hello all,
I've inherited 10+1x buried heating elements, so called 'fire rods' (not the flame sensors). They are rated 750W 230VAC each. 8.5x1.3 cm. They appear to be custom made, but I believe the max temp is around 700-800 degC.
What would make a useful project for a number of these?
Due to lack of better ideas I am leaning towards a large area heating plate - A number of these mounted under an aluminium plate and a buried thermocouple tied to a PID controller.
The 11th one might make an overkill coffee mug heater or chocolate melter.
Alex.
Offline Balaur
Re: Project with buried heaters
« Reply #1 on: October 23, 2013, 02:00:00 pm »
You can always build an electric Samovar.
Although you should always be careful of samovars. Who knows what's inside them!
Online Zero999
  • 0999
« Reply #2 on: October 23, 2013, 04:15:07 pm »
An etch tank.
« Reply #3 on: October 23, 2013, 04:21:33 pm »
Surely a proper Samovar uses charcoal. :-//
An etch tank.
Good idea.
Offline Alexei.Polkhanov
« Reply #4 on: October 23, 2013, 04:55:36 pm »
 ;D That story about bugged Samovar is pretty amusing - why isn't anyone bother to xray damn thing?
« Reply #5 on: October 23, 2013, 07:25:27 pm »
Not that uncommon, they are used as heater elements in extrusion moulders and other plastic injection moulding and forming equipment as a heat source, and to make heating plates. They are typically enclosed fully in a block though, not attached to the surface in a hole only slightly bigger than the element so that they are a firm slide fit but are not loose. Typically you run them up to 300c in the block.
