see attached.
S1 has the potential to short to 160V. since ground is at 80V above earth, the 160V supply will look like an 80V short.
I want to protect the output of my LDO with a 100V diode so current cannot flow into my 3.3V and 5V supplies from S1.
My Schottky implementation at the bottom does not work because the forward voltage drop is too great, and it will cause my 3.3V supply to droop to 2.9V, which is unacceptable. I cannot find a 100V diode with a Vf of <300mV @ 100mA. So that implementation does not work.
I then think to put the Schottky on the input of the LDO, because if my 5V droops to 4.2 V or so, that wont matter casue it can still regulate to 3.3V.
But the whole point is to protect the LDO, and if the schottky is on the input I worry the chip will get fried still even though it would protect everything else on the 5V rail.
