Electronics engineering student here, school project time, we are supposed to use diodes and make a proyect that its supposed to be helpful and usefull along our careers, it doesnt have to be complicated as long as we design it
Since the mains at some labs (a bit old some of them ) are giving up to 137 volts and at home at night the mains voltage can go up to 132 volts i decided to attemp to use a zener diode as a voltage regulator
So a portable voltage regulator, this way if i decide to plug it at the lab or at home and be absolutely sure im using 127v when its plugged instead of 137 or more
however i still dont understand completely how power and current relation works, i do know
P=VI
So at school this would look something like this
P=(137)(X)
X being whatever current the load needs to work
however how can i know how many watts does the resistor to protect the zener diode has to be for this AC aplication if i will never know how much current the load of my breadbord circuits will pull so how can i make this without knowing that ?
also, i tried looking for a 127v Zener diode and i did not find any
so in the end i ask
Up to now i have been rectifing and regulating DC however, im wondering if its posible to regulate AC using diodes without taking out half AC cycle (because zener is still a diode), other wise my brain somehow tells me its not possible using diodes, but i cant imagine any other way to do this
Do 127v zener diodes Exist? (already tried newark, mouser and digikey only found 120v and 120v zeners)
How can i do this,? mostly any feedback or ideas
picture semirelated, (same application but DC), what i want to do just take out the transformer, rectifier bridge and the capacitor
