Author Topic: Prop: Heartbeat on an oscilloscope  (Read 1577 times)
Offline NivagSwerdnaTopic starter
« on: January 24, 2022, 12:07:17 pm »
I've been asked.... would it be possible to have an oscilloscope show a heartbeat so it could be used as a prop sitting in the background of a film (amateur!) scene...
This must have been done before... any pointers?
Thanks in advance
PS
The signal can be pre-recorded... doesn't need attaching to anyone!  (Also... it can be repetative... no flat lining required!)
« Last Edit: January 24, 2022, 12:09:29 pm by NivagSwerdna »
Online themadhippy
Re: Prop: Heartbeat on an oscilloscope
« Reply #1 on: January 24, 2022, 12:25:00 pm »
how about recording of a heartbeat  fed into the scope
Offline jpanhalt
« Reply #2 on: January 24, 2022, 12:26:31 pm »
I used a MAX9814 breakout board that included an electret microphone (various sources, including Adafruit and DK) to record clock beats.  It also worked with my pulse.  For a recording, I just used my Rigol and a saved a screen to a thumb drive.  Background noise can be a problem but should be easy to clean up (attachment 2).
Offline Labrat101
  • Regular
  • Renovating Old Test Equipment & Calibration ..
« Reply #3 on: January 24, 2022, 12:29:40 pm »
Us a cheap signal gen they have this function.
"   All Started With A BIG Bang!! .  .   & Magic Smoke  ".
Offline mc172
« Reply #4 on: January 24, 2022, 12:32:25 pm »
I would use a computer with the scope connected to line out. You could simply draw the waveform you want in Audacity (free) with the pen tool and have it repeat the waveform indefinitely.
The following users thanked this post: ajb, NivagSwerdna
Offline Labrat101
  • Regular
« Reply #5 on: January 24, 2022, 12:53:41 pm »
You can down load the pulse from YouTube . or similar for cheap results
« Last Edit: January 24, 2022, 01:01:52 pm by Labrat101 »
The following users thanked this post: NivagSwerdna
« Reply #6 on: January 24, 2022, 01:04:38 pm »
That's interesting... wasn't aware of that function.  Thx
Offline msuthar
  • Country: in
« Reply #7 on: January 24, 2022, 01:15:29 pm »
HP function generator 33120A was able to output  a stored waveform of heart beat , if you can manage to get one unit then it is off the shelf wave form !
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #8 on: January 24, 2022, 01:30:15 pm »
And when the patient is dead, well that's a built-in trace so no worries.  :-DD
Offline Labrat101
  • Regular
« Reply #9 on: January 24, 2022, 05:57:27 pm »
If you had read the first Post  .. it's 4 a stage prop .. Not for the last post .. R.I.P    :palm:
Offline TimFox
« Reply #10 on: January 24, 2022, 06:23:55 pm »
It's a common scene in film and TV to show the scope trace of an EKG that goes to flat line at death.
Offline mendip_discovery
« Reply #11 on: January 24, 2022, 07:26:11 pm »
TV/Film tends to have a device, cover the screen in blue tape and then place the screen footage in post.
For your purpose, it might be easier to just use a raspberry pi, and an LCD screen in an old Scope box and just play a video and just time it right.
Motorcyclist, Nerd, and I work in a Calibration Lab :-)
So everyone is clear, Calibration = Taking Measurement against a known source, Verification = Checking Calibration against Specification, Adjustment = Adjusting the unit to be within specifications.
Online SiliconWizard
« Reply #12 on: January 24, 2022, 07:43:55 pm »
For people willing to have a more flexible solution, you can have a look at this: https://physionet.org/content/ecgsyn/1.0.0/
You can directly take the 'ecgsyn.dat' file (just a space-delimited CSV) in the 'sample-output' directory if you don't want/need to generate your own data.
You could play that back using a sound card, or using a small microcontroller.
Online MarkL
« Reply #13 on: January 24, 2022, 09:55:49 pm »
Not sure how fancy a scope you can get access to, but some scopes have have built-in waveform generators and "Cardiac" is a waveform choice.  You can put the scope in horizontal roll mode and it looks like a strip recorder.
An external monitor output on many scopes can get you a bigger display if it needs to be obvious.
Below is an Agilent MSO3000 series.  I'm sure similar functionality can be found on other make/models.
Offline DeanA
    • Design Electronics
« Reply #14 on: January 24, 2022, 11:40:29 pm »
Just get one of these https://theorycircuit.com/pulse-sensor-arduino/ and connect it to the scope with finger attached.
