MarkF.
I don't know the airflow. But know from the Kerr article that about 4 inches of water manifold pressure is desired (about 0.15 psi or about 0.01 bar). The Kerr article also gives the throat sizes he used. I used those for guidance. The limitation of the Kerr design is that he was forced to compromise on pipe diameter by the limited available stock sizes. He also chose not to individually select the flow limiting throat diameter. 3D printing and using rolled tubes of thin aluminum flashing allows avoiding those compromises and makes fabrication easier. I have built a test pipe and it works fine blowing through it with my mouth. I have also printed the valve and valve seat and they seal amazingly well. The cheap solenoids I plan to use arrive next week (that is the latest promise, the original promise was last week) and I will be able to verify that the forces and throw work out. The calculations say they will, but the proof will be in the pudding.
This weeks project is finishing the design and fabrication of a small 3D printed slip roll to make rolling the flashing into tubes easier. The test pipe was hand formed around a pipe. It doesn't have to be perfect, the tubes are clamped between external rings and internal forms.
If I am forced to roll my own controller the architecture I plan is to make a tiny board with pass transistor or FET and commutating diode to attach directly to the solenoid. Power and ground bussed through all the pipes leaving only a signal wire to go to each local drive board. Then a control board with 6 8-bit latches, an MCU to read and decode the MIDI input and necessary power and I/O support for USB receipt of .mid files. Have just started a survey of MIDI software libraries. This control board and associated software is the part I want to avoid. I can do it. It isn't a huge job. But I am not motivated at the moment.
