If you want to use the 74-compatible logic series, I'd probably recommend 74HC14 instead of LS. You can easily use them to create one-shots by connecting them as shown in the right ride of the image below.
When I'm using phototransistors, I usually connect them so they are current sinking instead of sourcing. Of course, in that configuration, their output is inverted, that is, it goes logic HIGH when the light path is blocked. See below, left side.
