The first cfl bulb called the yelly jar from the 80s had an average lifespan > 20 years, it had an copperiron ballast
The Philips SL, I had one of those a Philips rep gave me when I was about 5 years old and my dad took me to a lighting industry convention. Choke ballast with preheat start, that's about as gentle on the cathodes as it gets. They were not very efficient by modern standards though, and they had rather lousy color rendition, and they were bulky and heavy, but they were quite revolutionary at the time.
Still have a number of CFL adaptors, that are a regular B22 base, but you can fit in any regular PL lamp from 7W to 13W, with integral starter ( thus any 2 pin PL lamp) and it will run them. The lamps typically lasted 5-8 years on 24/7/365, and for those as dusk to dawn use the lamps did over 10 years, though of course I did use decent Osram or Phillips lamps. Those that are off brand do not last long, worst was a emergency relamp ( stock was due in a week, but needed the lamp now) that lasted 3 days before failing.
Now with the LED lamps I have a string of downlighters that used R80 reflectors, and I used to get around a year out of the Phillips R63 lamps I used, but started to use LED A shape lamps instead where they fitted in there. Interesting in that there are still 2 R63 lamps in there doing sterling duty, while there have been 4 LED lamp failures, which is sad considering the lamps have a rated life of 30k hours, but do not seem to be able to reach it based on the early data.
So, changed lamp type, and made a note that Radiant is not a good supplier of ANY lamp, and the fittings are no good either, just that they often are Hobson's choice in a pinch. Now using a cheaper one ( and saw yesterday Osram has one for the same price, just have to see if they are available in the cool white E27 base, and if they fit the downlighters) and have started marking on the base the install date, to get a life term.
Did pull out an old ( circa 1995) CFL adaptor I repaired around 1997 ( when they cost around $30 each, so fixing the stock faults of blown 1N4002 diodes and fusible resistor, yes a 200V rated diode on a 230VAC mains) and which had been sitting in a rarely used foyer since then. Still worked, though of course did take 5 minutes to come to full brightness, and still had the 10W PL lamp from there in it. Replaced with a 60W B22 incandescent, as this likely will last decades.
Funny thing is the metro still will install incandescent lamps in substation rooms and service corridors, where the light might only be turned on once a decade or so, but must work when needed, as CFL and LED lamps are not guaranteed to still work after 10 years sitting baking in the sun every day.
