yep.
pseudo differential means there is LEFT , RIGHT and a common return path shared by left and right.
So this is not a true differential signal where you would have left / left return , right / right return.
Essentially what this chip does is create a nullpoint signal (not the same as ground ! ) that is capacitively coupled onto the shield of the incoming audio cable.
The chip then does a difference calculation between this shield signal and left / right.
The problem is the following : if you tap into the audio output of a cellphone to bring it into an amplifier you are always screwed with teh GSM trasnmitter. as soon as this sucker starts blasting away the common mode signal injected onto the audio cable is audible in the speakers.
By cutting the shield off the ground and connecting it to the nullpoint you can run a difference amplifier on both signals thus rejecting the GSM signal ( which is common mode )
The end result is crystal clear audio without the prrrrrt prrrrt prrrrt of the gsm bursts.
This TDA8579 chip was specifically designed for that purpose and is part of the reference design audio interface for that fruity company.
I was trying to avoid that chip as neither digikey nor mouser carry it but it seems it is sold en masse on ebay.
This thing is part of a design i am doing for a new book on PCB design. The project is a mini-hifi system that combines FM radio , audio input, iDevice interface , PC audio card with USB , USB hub , graphics displays , switch mode power amps , high voltage switcher , mechatronics and flex boards.
I am trying all kinds of different things in this design from power, high voltage, RF , audio , high speed digital , flex pcb (for the remote control ) , capsense and anything i can think of.
Besides being the big democase it has to work well ...
