Author Topic: Using adjustable 1117 LDO as fixed 1.25v  (Read 661 times)
Offline c64Topic starter
« on: March 12, 2022, 11:28:02 pm »
I need 1.25v power source. I have adjustable version of 1117 LDO (which has 1.25 reference voltage).
Is it OK if I just connect ADJ pin to ground and don't use any resistors?
Offline floobydust
Re: Using adjustable 1117 LDO as fixed 1.25v
« Reply #1 on: March 12, 2022, 11:31:56 pm »
Yes. It does have a need for a minimum load, likely 10mA.
The following users thanked this post: c64
Offline magic
« Reply #2 on: March 13, 2022, 07:31:21 am »
I have used LM317 with grounded ADJ pin as a replacement for some unidentified 1.2V output buck converter that blew up.
Online wraper
  • Country: lv
« Reply #3 on: March 13, 2022, 08:45:16 am »
Yes you can do so. Check a datasheet for a minimum load spec as it's different for various sorts of 1117.
