Author Topic: Absolute Value Current Sense Amplifier Circuit?  (Read 3401 times)
Offline hal9001Topic starter
« on: March 20, 2022, 10:44:03 am »
Is there a current sense op amp circuit to output the absolute value of the current in terms of positive volts. In other words even if current direction changes I want to know how much current is going through a current shunt but dont care about direction.
Cheers!
Offline StillTrying
  • Country: Broken Britain
Re: Absolute Value Current Sense Amplifier Circuit?
« Reply #1 on: March 20, 2022, 11:45:02 am »
You could connect 2 of the constant current outputs to the same output resistor. :)
The following users thanked this post: hal9001
Offline Terry Bites
« Reply #2 on: March 20, 2022, 03:34:53 pm »
You need a current monitor and a simple absolute value circuit. 1444234-0 Many RIRO precision opamps will work.
The current sensing method you need depends on the current, system voltage and frequency. 1444240-1.
A simple method would be to use a high CMV differential amplifier (which you can home brew with loss of accuracy). This IC will work on a 120V RMS AC system1444246-2
« Reply #3 on: March 21, 2022, 10:25:43 am »
You need a current monitor and a simple absolute value circuit. (Attachment Link) Many RIRO precision opamps will work.
The current sensing method you need depends on the current, system voltage and frequency. (Attachment Link) .
A simple method would be to use a high CMV differential amplifier (which you can home brew with loss of accuracy). This IC will work on a 120V RMS AC system (Attachment Link)
Thanks!
Offline Terry Bites
« Reply #4 on: March 22, 2022, 01:37:06 pm »
You are so right.
There are exotic and more precise expensive versions I looked at before the penny dropped.
https://www.analog.com/en/app-notes/an-105fa.htmlF   (page 28) well worth a full read.
Bidirectional Absolute Value Current Sense using LTC6101 or LTC6102.
See https://www.analog.com/media/en/technical-documentation/data-sheets/ltc6101.pdf page 18 on boosting operating voltage if you need to.
Or https://www.analog.com/media/en/technical-documentation/data-sheets/6102fe.pdf
