Ok,
Thanks for that,
I have made the change (see below).
Being AC, I guess it does not matter which way the Live and Load are connected to the MT1 and MT2 terminals (or does it)
Also R8-11, can they be 1/4 watt, or do they need to be a bit more.
The system is 230v, and is going to be for dimming Halogen Lighting
The snubber Resistor and capacitor, what do you think the Ideal Values (and wattage) should be?
And Some people say I need a Ferrite Coil for EMI Suppression. Can that be between the Output pin and the fitting, or does it need to be between the Triac and the Snubber Network? And I have seen several values recommended. What is the rule-of-thumb for the Henries (I understand that the current through the coil is going to be the Full Load Current.
Thanks for helping with all my questions.
I am trying to get this done ASAP, because I need to order the PCB's this evening, (because if I do not pay the DHL fees, it will takeabout 60 days to get the boards through our wonderful
postal service.)
