Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
PT2262 RF ENCODER
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: PT2262 RF ENCODER (Read 1774 times)
stern0m1
Contributor
Country:
PT2262 RF ENCODER
on:
February 13, 2020, 09:24:24 pm »
Is there something similar to the PT2262 Encoder that the address bits are randomly set by the manufacturer of the chip? Requiring no programming
http://www.princeton.com.tw/Portals/0/Product/PT2262_5.pdf
Thanks!
Last Edit: February 13, 2020, 09:53:06 pm by stern0m1
Logged
floobydust
Super Contributor
Country:
Re: PT2262 RF ENCODER
Reply #1 on:
February 13, 2020, 10:55:47 pm »
One alternative is
PT2272
or Holtek HT12E or EV1527 (learning code) or
Holtek HT6P20.
Most of the new tech IC's are code-learning. That PT2262 IC is low security because it uses fixed code and vulnerable to copycat attacks.
Linx
sells the complete remotes, receivers, IC's too from Digikey.
Logged
stern0m1
Contributor
Country:
Reply #2 on:
February 13, 2020, 11:37:47 pm »
Thank you for the information.
All of these require, in one shape or another setting the "address". No one makes an encoder with an option for the "address" to be just randomly set by the ic manufacturer?
Logged
floobydust
Super Contributor
Country:
Reply #3 on:
February 14, 2020, 01:05:02 am »
EV1527
has a factory 20-bit address (1,048,576) pre-programmed I think. It's just a button press on the receiver to learn and accept this. This IC part is in many eBay little remote boards.
Logged
stern0m1
Contributor
Country:
Reply #4 on:
February 14, 2020, 09:56:48 am »
Which chip is used to decode ev1527?
Thanks
Logged
ebclr
Super Contributor
Country:
Reply #5 on:
February 14, 2020, 06:51:56 pm »
http://www.sc-tech.cn/en/2272en.htm
Logged
stern0m1
Contributor
Country:
Reply #6 on:
February 14, 2020, 10:07:48 pm »
How do you set it to" learn" the preprogrammed address in the 1527?
The datasheets are not really clear.
Thanks
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PT2262 RF ENCODER
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
