Hi all,
I was playing around with an active filter for a PLL I built. The filter was designed with ADISimPLL and built with an ADF4002 PLL chip and SP869 VCO. I never gave much attention to the opamp in the circuit and started out with a OPA227 (low noise, GBW of 8MHz). The loop filter had a designed bandwidth of 10kHz. When I built it up, the output was extremely dirty, not really locking at all. The Vtune signal was a nice triangle though. Then I switched to the LT1115 (GBW of 70MHz) and it would lock, but still a very dirty spectrum on the SA. Adding some caps between output and input of the opamp ameliorated the situation.
Now comes my questions: what are the typical caveats with designing active PLL loop filter that aren't mentioned in the app notes?
