Author Topic: Pulse skipping on Vneg of TPS65130  (Read 1228 times)
Offline thmjprTopic starter
« on: January 18, 2020, 10:32:54 pm »
TPS65130
Split-Rail Converter with Dual, Positive and Negative Outputs (300mA typ)
Datasheet: http://www.ti.com/lit/ds/symlink/tps65130.pdf
5V in and getting +/- 8V out.
Positive supply is working fine, 1.3MHz constant, with minimal ripple:
Negative supply is stuck in pulse skipping mode producing a ton of ripple:
The device has power save mode, enabled by pulling PSN (power save negative) or PSP to Vin. Disabled with Gnd.
Soldering:
- PSN and PSP pin continuity checked to Gnd, looks ok under microscope as well.
- I only had the one chip (new from LCSC), so will update when I receive and test another chip. Going to try a TPS65131 as well (higher current version).
Inductor:
- 4.7uH recommended, 10uH is being used. Tried a 4.7uH and skipping was still present.
Load:
- No load or 20mA load didn't change anything.
Anything I might have missed?
Some other discussions:
https://www.eevblog.com/forum/projects/tps65131-split-rail-power-board/
https://e2e.ti.com/support/power-management/f/196/t/717199?TPS65131-negative-output-voltage-abnormal
« Last Edit: January 18, 2020, 10:38:19 pm by thmjpr »
Offline SiliconWizard
Re: Pulse skipping on Vneg of TPS65130
« Reply #1 on: January 19, 2020, 01:08:39 am »
Sorry if I've missed it, but I didn't see any capacitor at +Vo and -Vo.
That's probably going to be a problem.
The following users thanked this post: thmjpr
« Reply #2 on: January 19, 2020, 03:35:48 am »
My fault, its in another area of the circuit. 47uF on each +Vo and -Vo to Gnd. 25V 47uF X5R.
Recommended value is 22uF.
Making it larger might help but I suspect it will still skip.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: January 19, 2020, 06:06:32 am »
Are you sure it's not compensated incorrectly?
Pulse skipping is, well, skipping pulses, but that's a burst waveform.  Some controllers still do that, but I don't know if that's typical for this one.
Seven Transistor Labs, LLC
« Reply #4 on: January 20, 2020, 07:43:58 am »
You are right the terminology is confusing, its more of burst/sleep mode. TI seems to like to call it that:
The converter operates with a fixed frequency PWM control topology and, if power-save mode is enabled, it uses a pulse-skipping mode at light-load currents.
I've tried with Cn, compensation cap removed, no major difference seen there.
With Cf-, feedforward capacitor removed, duty cycle of the pulses increases to ~%50, ripple reduces significantly, and power consumption goes up a bit. So thats on the right path. But removing it is too risky.
Note here about >33uF not recommended, but I'm getting same issue with lower values: https://e2e.ti.com/support/power-management/f/196/t/799796
Also there, at a point below ~80mA on the Vneg, discontinuous conduction occurs.
When testing today I found dropping Vin from 5V to ~4.2V would kick it out of power-save mode and into normal PWM. It would also get into some wild states above 5.3V. Might need to play with that a bit more..
