Hi!
Just an update about the small project I am doing and some questions that arose.
I finally decided to use only the BPW34 photodiode because I replaced the 5V op amp with the LM358P
which has a broader choice of supply voltages. I am using now a 9V battery that gives me a wider
voltage range making the UT102C “more” sensitive. I’ve also replaced the feedback resistor with a 4K
one for more amplification. Now the circuit can read the frequency of a mobile phone screen in broad
daylight. The photodiode does not get saturated and you can use it in the morning with no problem.
You can measure the frequency of a 60watt mains bulb, while shinning a 1000 lumens flashlight directly
above the diode…
Then it struck me! What about if you can also hear the light source? I connected the output of the small
circuit to an LM386N audio amplifier with a speaker and the whole project become more interesting now.
You will be able to measure the frequency of the light source and hear it at the same time! (depending
on the speaker you have of course…)
Check out the video below where I measure and listen to several sources of pulsing lights:
(one of them is very interesting) (again, sorry for the video quality but I do not have a decent
video camera)
The LM386N datasheet states that the absolute maximum of the inputs voltage is 400mA. My question
is, what happens if you exceed that limit? Is there any danger of destroying the thing? I have measured
the maximum peak to peak voltage from the preamp and I have used a voltage divider on its output to
the LM386N just to be sure.
Below is the revised circuit schematic:
free image hostingMy other question is that while the whole thing works very well, when I connect the output of the
preamp to the input of the amp, the signal gets distorted. It has some small peaks and valleys, it gets
attenuated a bit and phase shifted as well ! The photodiode amplifier outputs a perfect sine wave if the
LM386N is not connected. (mains light source)
The probing points are: Output of C1 for the yellow signal (photodiode amp) and Output of C5 for the
blue signal (amp).
Preamp signal only
Preamp & AmpIs this normal ?
(The distortions get more pronounced on very fast signals)
Finally, I know that by changing R5 I can increase or decrease the output of the photodiode amplifier,
but how can I implement a speaker volume control?
Thank you!
