Uhh...
N...well, yes, I guess, definitely?
You have precisely such a relay -- just connect your insanely expensive DC load in series with the desired load, program it to ramp from 30 to 0V in 1s, and there you have it!
As a lone component, you are expecting something to be able to dissipate up to three kilowatts for a whole second. A quick perusal of available devices says no. Very few semiconductor devices handle that much power at all; among them, none do it continuously, or down to an arbitrarily low "on" voltage (e.g., industrial IGBT modules). Such a unit must use multiple devices in parallel, with a control circuit to stabilize and equalize the power between them. (A typical e.g. TO-247 sized power transistor will be able to handle maybe 100-300W each over this time frame, so expect to need 10 or more. Or there are other configurations that can use fewer transistors and a cheaper power dissipator (like a dumb resistor), but at expense to e.g. speed or emitted noise.)
Perhaps it doesn't need to be as precise, or fully-featured, as your load is. Perhaps a cheaper model, of similar overall capability, would suffice? I guess I don't get it; you're testing "a" power supply, and you already have the load -- what's the problem? Is it rented and you'll be testing for a while? Are there multiple supplies being tested, in production perhaps? What's the test budget? Etc.
You could make your own perhaps, but the design time spent for a one-off, won't be cheaper than your off-the-shelf unit, at least if you just need a few. And it won't be as well characterized and calibrated as the commercial unit is.
