Go to DigiKey.com, opamps, specify your desired package and supply rails, then inverse sort on "Quantity Available". The first few results will give you a nice snapshot of parts that are consumed, and thus stocked, in high(er) volumes. From there you can drill down to additional criteria such as performance and cost.
