PCBs in reference to transformers is insulating/cooling oil that was used in large utility transformers and as a dielectric in some types of oil filled capacitors found in fluorescent ballasts and such up into the 1970s, it's not something you're going to find in a PC power supply.
I didn't do an exhaustive investigation into the failures I had but from what I could tell they were typical of the cascading failures that tend to occur in these things. Something caused one of the mosfets in the half bridge to short which blew the other mosfet and the resulting direct short blew up the rectifier and other stuff until the fuse blew and opened the circuit. In the one that fried the motherboard I suspect something caused the feedback loop to open up and the regulator went balls out full throttle until it blew up, but there's no way to know for sure. In both cases I walked in, pushed the power button and BANG!
Interesting. I suppose I got lucky with my failure. What was weird was that it was a prolonged failure which stopped shooting colorful sparks when unplugged, but resumed when the idiots refused to take my word that it failed and proceeded to plug it back in.
That was part of the reason that I mentioned HV transformers & PCB's. I know PCB's all too well, as I grew up in Pittsfield, MA. Was A HUGE GE boom town that housed much of their power transformer business along with r&d until they pulled up stakes, leaving a huge mess of PCB's and other contaminants behind. I believe it was an EPA super fund site. Still not cleaned up completely, and I went to elementary school on a site in which they had to remove a few feet of soil, put a barrier down, then back fill with clean soil. Shit is still in the water table, just at "acceptable" levels now.
My PS failure just reminded me of a few large transformer failures that cascaded somewhere in the plant/lab. Those were some really awesome light shows.
I couldn't dissect mine as they definitely wouldn't have taken it back with broken seals.
Still amazed at what seemed like a very miniature version of those cascading power transformer failures I witnessed at GE though. And no big bangs either. Plenty of what sounded like "arc popping" though, also similar to those large transformer failures.
But I guess I'll never know. Probably just junk shorting and burning various materials.
I shouldn't make inside jokes that only include me, due to bitterness of what GE did to my hometown. LOL.
It's been an interesting discussion though. Just shows how things can go terribly wrong with any scale of power transformation gear. Only difference is the monetary scale. Our PS failures ranged from a couple hundred bucks to probably a couple grand, whereas I could have built a super computer cluster a few times over with the about of money that went up in smoke with what I saw at GE.
Hopefully we won't be adding any more personal experience to PC PS failures!!
