Hi Folks!
I now own a new Rigol DS1054Z oscilloscope and I did some measurements. I measured the output of a transformer (230VAC to 12VAC) and I was expecting the 50Hz sine wave (Europe). It was there, but the frequency counter showed some weird value:
Can someone explain, why the counter is so wrong this time? With other measurements it was pretty spot on. What can be the reason? It also recongizes the 50Hz on input side correctly.
Thanks!
