Author Topic: Qtouch - How to bridge a 3-5 mm gap between PCB and touch surface  (Read 798 times)
Online ricko_ukTopic starter
I have a PCB with a number of Qtouch pads but mechanically there is a gap between the PCB top surface (with the pads copper is) and the bottom of the 3mm-thick plexiglass front panel.
Such air gap is fixed once the design is finalised but at this stage can be anything from 3 to 5 mm.
Any suggestions on how I can electrically/capacitively "couple" the plexiglass touch area to the PCB copper pad? One solution would be to have a metal spring (which being conductive would transfer the charges). But cannot find any spring that is soft enough and which is only few mm long while being also 10-15mm in diameter.
Any other solutions?
Thank you :)
Offline Gyro
Re: Qtouch - How to bridge a 3-5 mm gap between PCB and touch surface
« Reply #1 on: May 08, 2020, 06:22:37 pm »
Pads of soft (Black) antistatic foam, cut to size / shape? You should be able to get resistance down to a few k.
« Last Edit: May 08, 2020, 06:36:53 pm by Gyro »
Best Regards, Chris
The following users thanked this post: ricko_uk
Online ataradov
    • Personal site
« Reply #2 on: May 08, 2020, 06:27:05 pm »
They sell springs that widen into a bigger "pad" just for that purpose. I'm not sure if any of them are 3-5 mm though.
Here is one example https://www.aliexpress.com/item/32655220502.html . This is just a first link I found. They should be available from regular parts suppliers as well.
Alex
« Reply #3 on: May 08, 2020, 10:18:41 pm »
Thank you Gyro and Ataradov! :)
Gyro, have you tried it or do you know someone who has?
Many thanks
Offline Gyro
« Reply #4 on: May 09, 2020, 09:47:51 am »
Not personally, but I doubt an extra few k on a capacitive touch switch would have a significant effect (as I say, use the soft black conductive stuff, not the pink dissipative one). It sounds as if it would be fairly quick to test (you must have an old IC box kicking around somewhere).
« Last Edit: May 09, 2020, 09:49:52 am by Gyro »
Best Regards, Chris
« Reply #5 on: May 09, 2020, 06:11:51 pm »
Thank you Gyro! :)
Online jbb
« Reply #6 on: May 09, 2020, 09:57:35 pm »
There are surface mount spring contacts which might do the trick... but end in basically a point.  Digikey carries some.
For prototyping, how about sticking some squares of copper tape to the inside of the plexiglass? If going to volume production, it may be practical to get a conductive film or ink or something applied to the plastics for you.
Alternatively, a different technology approach is to stick a flex PCB to the plexiglass and put the Touch pads on that.  Might also allow fun stuff like using a curved panel, or bending around a corner to put 'buttons' on the sides.  You can also get quite interesting stuff done on an FPC, like soldering the QTouch chip or LEDs onto it, adding stiffeners for support or simply adding some double sided tape.
Yes, adding an FPC is more parts and money, but it might be a win overall.  For example:
  • maybe you could shrink your main board if it doesn't need big Touch contacts
  • change the main board mounting location and get some internal volume back
  • use the FPC to reach some other stuff in the box (e.g. external connectors)
  • leave a little wiggle room on the FPC to soak up mechanical tolerances in your design
« Reply #7 on: May 10, 2020, 12:15:51 am »
Thank you JBB,
all valid and interesting points! :)
