Author Topic: Frequency Divider Circuit issue  (Read 2089 times)
Offline promachTopic starter
« on: May 26, 2019, 02:42:27 pm »
I am trying to implement a divide-by-two circuit quoted from the book "Low power CMOS circuits : technology logic design and CAD tools" by Christian Piguet
Could anyone advise about the spice error "timestep too small" ?
mosfet_018.lib
* modified for use with LTSpice; DM 8/19/2008
* 0.18u CMOS process
* NMOS transistor model name: NM
* PMOS transistor model name: PM
.subckt NM D G S B
+params: W=10u L=1u
M1 D G S B NM L={L} W={W} AS={1.1u*W} PS={2.2u+W} AD={1.1u*W} PD={2.2u+W}
.ends
.MODEL NM NMOS LEVEL=49
************************* SIMULATION PARAMETERS ************************
* format    : LTspice
* model     : MOS BSIM3v3
*                        TYPICAL MEAN CONDITION
+VERSION = 3.1            TNOM    = 27             TOX     = 4.1E-9
+XJ      = 1E-7           NCH     = 2.3549E17      VTH0    = 0.354505
+K1      = 0.5733393      K2      = 3.177172E-3    K3      = 27.3563303
+K3B     = -10            W0      = 2.341477E-5    NLX     = 1.906617E-7
+DVT0W   = 0              DVT1W   = 0              DVT2W   = 0
+DVT0    = 1.6751718      DVT1    = 0.4282625      DVT2    = 0.036004
+U0      = 327.3736992    UA      = -4.52726E-11   UB      = 4.46532E-19
+UC      = -4.74051E-11   VSAT    = 8.785346E4     A0      = 1.6897405
+AGS     = 0.2908676      B0      = -8.224961E-9   B1      = -1E-7
+KETA    = 0.021238       A1      = 8.00349E-4     A2      = 1
+RDSW    = 105            PRWG    = 0.5            PRWB    = -0.2
+WR      = 1              WINT    = 5e-9              LINT    = 2.351737E-8
+DWG     = 1.610448E-9
+DWB     = -5.108595E-9   VOFF    = -0.0652968     NFACTOR = 2.4901845
+CIT     = 0              CDSC    = 2.4E-4         CDSCD   = 0
+CDSCB   = 0              ETA0    = 0.0231564      ETAB    = -0.058499
+DSUB    = 0.9467118      PCLM    = 0.8512348      PDIBLC1 = 0.0929526
+PDIBLC2 = 0.01           PDIBLCB = -0.1           DROUT   = 0.5224026
+PSCBE1  = 7.979323E10    PSCBE2  = 1.522921E-9    PVAG    = 0.01
+DELTA   = 0.01           RSH     = 6.8            MOBMOD  = 1
+PRT     = 0              UTE     = -1.5           KT1     = -0.11
+KT1L    = 0              KT2     = 0.022          UA1     = 4.31E-9
+UB1     = -7.61E-18      UC1     = -5.6E-11       AT      = 3.3E4
+WL      = 0              WLN     = 1              WW      = 0
+WWN     = 1              WWL     = 0              LL      = 0
+LLN     = 1              LW      = 0              LWN     = 1
+LWL     = 0              CAPMOD  = 2              XPART   = 0.5
+CGDO    = 7.7E-10        CGSO    = 7.7E-10        CGBO    = 1E-12
+CJ      = 1.010083E-3    PB      = 0.7344298      MJ      = 0.3565066
+CJSW    = 2.441707E-10   PBSW    = 0.8005503      MJSW    = 0.1327842
+CJSWG   = 3.3E-10        PBSWG   = 0.8005503      MJSWG   = 0.1327842
+CF      = 0              PVTH0   = 1.307195E-3    PRDSW   = -5
+PK2     = -1.022757E-3   WKETA   = -4.466285E-4   LKETA   = -9.715157E-3
+PU0     = 12.2704847     PUA     = 4.421816E-11   PUB     = 0
+PVSAT   = 1.707461E3     PETA0   = 1E-4           PKETA   = 2.348777E-3
.subckt PM D G S B
+params: W=10u L=1u
M1 D G S B PM L={L} W={W} AS={1.1u*W} PS={2.2u+W} AD={1.1u*W} PD={2.2u+W}
.ends
.MODEL PM PMOS LEVEL=49
* format    : LTSPICE
+XJ      = 1E-7           NCH     = 4.1589E17      VTH0    = -0.4120614
+K1      = 0.5590154      K2      = 0.0353896      K3      = 0
+K3B     = 7.3774572      W0      = 1E-6           NLX     = 1.103367E-7
+DVT0    = 0.4301522      DVT1    = 0.2156888      DVT2    = 0.1
+U0      = 128.7704538    UA      = 1.908676E-9    UB      = 1.686179E-21
+UC      = -9.31329E-11   VSAT    = 1.658944E5     A0      = 1.6076505
+AGS     = 0.3740519      B0      = 1.711294E-6    B1      = 4.946873E-6
+KETA    = 0.0210951      A1      = 0.0244939      A2      = 1
+RDSW    = 127.0442882    PRWG    = 0.5            PRWB    = -0.5
+WR      = 1              WINT    = 5.928484E-10   LINT    = 3.468805E-8
+DWG     = -2.453074E-8
+DWB     = 6.408778E-9    VOFF    = -0.0974174     NFACTOR = 1.9740447
+CDSCB   = 0              ETA0    = 0.1847491      ETAB    = -0.2531172
+DSUB    = 1.5            PCLM    = 4.8842961      PDIBLC1 = 0.0156227
+PDIBLC2 = 0.1            PDIBLCB = -1E-3          DROUT   = 0
+PSCBE1  = 1.733878E9     PSCBE2  = 5.002842E-10   PVAG    = 15
+DELTA   = 0.01           RSH     = 7.7            MOBMOD  = 1
+CGDO    = 7.11E-10       CGSO    = 7.11E-10       CGBO    = 1E-12
+CJ      = 1.179334E-3    PB      = 0.8545261      MJ      = 0.4117753
+CJSW    = 2.215877E-10   PBSW    = 0.6162997      MJSW    = 0.2678074
+CJSWG   = 4.22E-10       PBSWG   = 0.6162997      MJSWG   = 0.2678074
+CF      = 0              PVTH0   = 2.283319E-3    PRDSW   = 5.6431992
+PK2     = 2.813503E-3    WKETA   = 2.438158E-3    LKETA   = -0.0116078
+PU0     = -2.2514581     PUA     = -7.62392E-11   PUB     = 4.502298E-24
+PVSAT   = -50            PETA0   = 1E-4           PKETA   = -1.047892E-4
Offline RandallMcRee
Re: Frequency Divider Circuit issue
« Reply #1 on: May 26, 2019, 05:12:51 pm »
Google found this as a first step:
https://forum.allaboutcircuits.com/threads/time-step-too-small-in-ltspice.134249/
You might want to also put "ltspice timestep too small" in the title of your post to grab folks' attention.
If the google suggestions don't help maybe you can tell the forum what you tried that did not work, etc.
« Reply #2 on: May 27, 2019, 01:29:06 am »
With the help of others, I manage to make the circuit works.
But I still have some more questions.
1) Why use PULSE() instead of SINE() ?
2) Why Vdd=3.3V will make the circuit not working, but Vdd=1.8V will ?
Offline OM222O
« Reply #3 on: May 27, 2019, 04:02:52 am »
pulse is used since the circuit is digital, not analog. if you want to use a sine wave input / an input with low slew rate, often a schmitt trigger is sued to clean up the input to a nice square wave.
it seems your transients are too fast for the simulation engine, which is why you are getting those errors. I'm not sure how to fix it however. maybe reduce the input frequency?
« Last Edit: May 27, 2019, 04:10:26 am by OM222O »
« Reply #4 on: May 28, 2019, 05:03:59 am »
I need to confirm the biasing condition for each mosfets again before I could make further comments about this.
However, one thing that really concerns me is the LARGE mosfet sizing that could easily contribute to significant parasitic capacitance, which will definitely lead to speed slowdown.
I do not understand why the author claims that his dynamic divider circuit is "speed-optimized" ?
« Reply #5 on: June 01, 2019, 03:48:38 am »
How does this three-stage master-slave flip-flop using TSPC logic works as a frequency divider (÷2) ?
Offline Zero999
  • 0999
« Reply #6 on: June 01, 2019, 08:06:10 am »
Well 1.8V, rather than 3.3V, will slow it down.
Try reducing the rise and fall times of the input signal. It should force the simulator to use a smaller time step.
« Reply #7 on: June 01, 2019, 10:07:22 am »
No, this suggestion does not help to remove the error
Online iMo
  • Country: bj
« Reply #8 on: June 01, 2019, 10:37:04 am »
If you look at the current it rises 3x when Vcc goes from 1.8->2.2V..
Online SiliconWizard
« Reply #9 on: June 03, 2019, 03:46:15 pm »
Try increasing the channel width of your transistors (eg: L=180nm, W=360nm). You can probably significantly decrease the number of parallel devices (M) for each transistor for a reduced power consumption. You'll have to adjust the ratios a bit to get a satisfactory behavior.
(Attached is an example that simulates properly.)
« Reply #10 on: June 04, 2019, 12:59:40 am »
You can download the working circuit from https://github.com/promach/div_by_two
@SiliconWizard
By the way, my circuit is way more power-saving than yours in your post above.
Nevertheless, I am looking at another circuit below (c) with split-output latches that could further reduce the number of transistor and clock loading.
What do you guys think about this ?
« Last Edit: June 04, 2019, 01:01:15 am by promach »
« Reply #11 on: June 04, 2019, 11:09:47 am »
@SiliconWizard
I didn't notice a big difference. The sim gives an average of ~6.6µA with yours at 1.8V, 100MHz, and ~6.4µA under the same conditions with mine.
I pushed mine to 3.3V and 500MHz in the LTSpice file above and get  ~80µA. But give it the same conditions as yours and see. Likewise, with yours at 1.8V/500MHz, I get ~33µA, and ~32.4µA with mine. The difference doesn't look significant. And the point was to get it to simulate @3.3V, which doesn't work with yours. But do not hesitate to point out how you figured mine would draw more power, I may have missed something?
That aside, this circuit is basically some form of dynamic flip-flop and can be a bit tricky. Parasitic capacitances are actually part of the design rather than a problem, as long as they are correctly used. It will work properly under a limited range of conditions (including clock frequency and rise/fall times), so, to be used with caution. A quick overview here: http://www.seas.ucla.edu/brweb/papers/Journals/BRFall16TSPC.pdf
« Last Edit: June 04, 2019, 11:13:23 am by SiliconWizard »
« Reply #12 on: July 01, 2019, 04:53:19 pm »
Could you explain how the asynchronous reset input, M10 works in resetting the entire circuit asynchronously ?
As you can see from the following circuit screenshots, the M10 reset signal does not work in all situations.
« Last Edit: July 02, 2019, 01:43:35 am by promach »
