Author Topic: ULN Voltage reference, switchable 2-10 in 1V steps.  (Read 338 times)
Offline MasterTTopic starter
« on: May 13, 2024, 02:59:43 am »
 Here easy to build project, Ultra Low Noise voltage reference. Created for noise tests, mostly adc's.
And test results with  output set to 10V, can't say for sure what drive noise curve up at the low end, is it reference or SA input cap (been charging all day, about 50 nA leak at the moment). Data in nV/sqrt().
The following users thanked this post: Vovk_Z
Offline Vovk_Z
  • Country: ua
Re: ULN Voltage reference, switchable 2-10 in 1V steps.
« Reply #1 on: May 13, 2024, 05:58:39 am »
Quite simple. Thank you for sharing.  :-+
