A while back I asked about methods and materials to make a flat surface as part of an optical measurement system and it occurred to me that perhaps the better approach would be to do a more basic and less costly machining for flatness and then scan the part with a laser scanner. So, even if the machined part is off by +/- 250um a laser scanner with, say, 10um accuracy and point spacing of, say, 5mm x 5mm, would permit a calibration table that would compensate and allow a final output near the accuracy of the laser scanner or about 10um. More likely the resultant accuracy might be more like 20um and that would be more than adequate for my application. In fact, a final accuracy of 35um would probably be enough.
So, what options are there for laser scanners to permit scanning of a 230mm x 150mm plate and to do so within 10 seconds and preferably quicker? About what would something like this cost?
Brian
