Author Topic: SMT Spacers / Standoffs sturdy?  (Read 588 times)
Offline satyamfifaTopic starter
« on: March 09, 2023, 06:09:53 am »
Hey All,
I wonder how study and robust SMT Spacers / Stadoff such as these: offered by Würth are? Are the susceptible to vibrations if the PCB is mounted on a moving platform?
-Sparsh
Offline jc101
Re: SMT Spacers / Standoffs sturdy?
« Reply #1 on: March 09, 2023, 01:09:54 pm »
I hope pretty well, as I use them in devices fitted to light aircraft and for holding a display on in a handheld device.
Probably close to 10,000 out there now, and I've never had an issue.
I use the M3 threaded SMT posts in 5mm, 6mm, and 7mm lengths.
The following users thanked this post: thm_w, satyamfifa
Offline coppercone2
« Reply #2 on: March 09, 2023, 06:37:51 pm »
I don't know, I think you should drill a hole use the swage ones, or threaded.
I think the solder joint is very sturdy, it just depends on how much you trust the laminations and circuit board quality. That's not something easy to inspect IMO. At least like the right angle ones, the others are still sandwiched with a bolt so it does not matter too much.
« Last Edit: March 09, 2023, 06:40:50 pm by coppercone2 »
