I thought I'd post a fun circuit for people to play with - it was inspired by the University of Florida Open Source Emergency Ventilator project. But really it's just an adaptation of a handy 555-driven low power timer pulser circuit for AC or DC loads.
This could be used on other sorts of emergency ventilator designs - could be a piston-actuateg bag squeezer, peristaltic pumper, blower or some other breathing aid device. Could also be a roadside light flasher, Halloween decoration, or whatever you want.
This is only meant to be an example schematic and learning tool- users can develop their own modifications and Bill of Materials to suit whatever parts are available and whatever need they have.
Sometimes in this age of cell phone apps people forget how simple a timer circuit can be...
I'm not against using CPU's and MCU's in all sorts of systems - I make my living doing that at all levels. BUT SOMETIMES software just isn't required - and in the case of a product that needs emergency FDA clearance for cybersecurity, it's really handy to kick out an old school quickie 555 circuit. Just eliminate the software hacking problem altogether. Don't even need a PC board made either.
I know some readers might not be completely familiar with 555 timer circuits, or how to adjust the duty cycle of a timer with a simple comparator, or how to easily control a low power AC load with a small SSR chip. Here you go... Here's a super simple, super reliable and inexpensive way to help save someone's life - or make a cool gadget for a science fair or Halloween prop.
Link to a Google drive with example open source schematic, complete circuit description, oscilloscope shots taken during testing and an exciting demo movie.
https://drive.google.com/drive/folders/1wJ81SEzPLlEspD-UX3PU1LFRpdiZRutf?usp=sharingLink to Open Source Ventilator project:
https://simulation.health.ufl.edu/technology-development/open-source-ventilator-project/AGAIN: This is only an example that was built and validated based on parts we had in stock, and looking around at parts distributors to see what was in plentiful supply that's inexpensive. There are a million ways to do this circuit; this is ONLY an example.
Another note: Already I've been asked "Why not use a zero-crossing TRIAC chip to control the AC coil"? Because this circuit is designed to drive low power AC loads at 24VAC - namely a low power sprinkler valve with AC control coil. The zero crosser won't even work correctly at low AC voltages, and it's really not desired anyway for this use.
Have fun!
