Hello PCB.Wiz,Yes We need to match the absolute vslue of Vgs on bot mosfets at a certain time point, so they open at a certaint ime point.
We have node e starting to rise.
Its going to NPN ,whic has a resitor form one side the a diode on the other side.
NPN is just a valve to create certain Ic current.
Also the diode is touchin the drain.
What is the point in this?
Thanks.
