Author Topic: electrical logic of current limiting  (Read 932 times)
Offline john23Topic starter
  • Country: aq
« on: November 10, 2024, 05:23:57 pm »
Hello,given the schematics below the zener diode gets reversed biased at 4.7 V.
so the current is I=(15-4.7)/R .
we automatickly assume we have 4.7V on the zenner, and we can calculate the current by the resistor.
under what conditions the zenner will not enforce the 4.7V threw it?
Thanks.
https://www.mouser.co.il/datasheet/2/268/1N746A_1_1N759A_1_2c1N4370A_1_1N4372A_1-3442192.pdf
Online Andy Chee
Re: electrical logic of current limiting
« Reply #1 on: November 10, 2024, 05:40:52 pm »
Thanks.
when the current is too low (e.g. 1mA)
some good explanation here:
https://www.sound-au.com/appnotes/an008.htm
« Last Edit: November 10, 2024, 05:59:14 pm by Andy Chee »
Online TimFox
« Reply #2 on: November 10, 2024, 05:54:08 pm »
The behavior at very low currents, as  mentioned above, is more pronounced for lower-voltage "Zener" diodes, such as the  1N750, that are actual Zener diodes.
For nominal voltages above approximately 6 V, "Zener" diodes are actually "avalanche" diodes where the current increases faster with voltage than lower-voltage units, hence the voltage varies less with current.
For example, according to the ancient Motorola book, a 1N750 has 3.0 V across it for 0.1 mA through it, and 4.4 V at 10 mA.
The avalanche diode 1N754 increases from 6.4 V at 0.1 mA to 6.5 V at 10 mA, a much more constant voltage.
See page 4-6 of the 1967 edition of Motorola's Zener Diode Handbook.
  • Country: aq
« Reply #3 on: November 10, 2024, 06:31:50 pm »
Hello,There is a logical problem.
In order to calculate the zener current  threw the limiting resistor we always assume that zenner is working properly.
how can i know mathematickly  the current without assuming i have proper 4.7V across the zener?
Thanks.
Online TimFox
« Reply #4 on: November 10, 2024, 06:44:56 pm »
Thanks.
The data sheet only specifies voltage at a specific test current.
If you run the Zener diode at a much different current, its voltage will be different, especially for lower voltage units such as 1N746 through 1N750.
To calculate the Zener voltage with a fixed source and series resistance, you need to start with a graph of Zener voltage vs. current and draw a “load line” (determined by the source voltage and series resistance) to find the intersection with the non-linear Zener characteristic.
The Zener equations are more complicated than merely a “proper” voltage in series with a resistance:  that model is only useful for small variations in current around the specification point.
The load line for a source and resistor is the locus of voltage after the resistor as a function of the current flowing into the load (your Zener).
There is no logical problem here, just a very non-linear practical device.
  • Country: aq
« Reply #5 on: November 10, 2024, 07:02:47 pm »
Hello ,I have made such a plot, I see that in 9mA current I have good 4.7V output as shown below.
In the lab I have a voltage source of 12V , how this plot will help me decide what current limiting resistor to choose?
Thanks.
« Last Edit: November 10, 2024, 07:06:43 pm by john23 »
Online Andy Chee
« Reply #6 on: November 10, 2024, 07:18:29 pm »
Thanks.
You need to provide information about the load.
« Last Edit: November 10, 2024, 07:22:46 pm by Andy Chee »
Online inse
« Reply #7 on: November 10, 2024, 07:27:15 pm »
What are you using the Zener diode for, to generate a kind of reference voltage or as shunt regulator to supply a circuit?
As a reference generator, e.g. TL431 would be much more stable, also as shunt regulator.
Online TimFox
« Reply #8 on: November 10, 2024, 07:40:28 pm »
Thanks.
You mean, (12 - 4.7) V / (9 mA) = 811 \$\Omega\$  ?
As others have discussed above, there is more to specify to get a useful answer.
The plot I discussed adds a linear function Vload = Vsource - ( Iload x R ) and finds the intersection with the diode's I-V curve.
Often, the two plots are on a graph with voltage on the horizontal axis and current on the vertical axis, but it works either way.
The 1N750 is not designed as a reference diode.
« Last Edit: November 10, 2024, 07:44:21 pm by TimFox »
  • Country: aq
« Reply #9 on: November 10, 2024, 08:46:54 pm »
Hello, There is a similar case in NPN,I swept the base current.
I want to decide what base limiting resistor to use.
I made plots shown below.
I have 12V voltage source i want base current 37uA.
that meens my resistor is 12/37uA=R which is very very large.
Is there a way to reduce the need for such a large limiting resistor?
Thanks.
Online TimFox
« Reply #10 on: November 10, 2024, 09:54:15 pm »
Your drawing has emitter and collector labels interchanged.
In general, you don't specify the base current for a BJT circuit:  you specify the collector (or emitter) current and use the manufacturer's wide range of "beta" to calculate the correspondingly large range of base current, and make sure your driving circuit can supply that current.
If you look at the datasheet for a 2N3904 (for example), the manufacturer specifies (at a given collector current) a 3:1 range of "beta" (hFE for parts that pass the production test and are shipped to the user.
See  https://www.onsemi.com/download/data-sheet/pdf/2n3903-d.pdf
12 V/37 uA = 324 k\$\Omega\$, which is not "very very large".
In a real circuit, Vbe doesn't vary much across that range of base current, so the actual base current is very close to (12 V - 0.7 V)/Ib.
In your posted circuit, much of the "base" voltage is actually across the emitter resistor.
« Last Edit: November 10, 2024, 10:02:05 pm by TimFox »
  • Country: aq
« Reply #11 on: November 11, 2024, 06:32:25 pm »
Hello TimFox,I have build NPN which base is being  biased with a current source ,the  problem that My collector current is very low  no matter the current i put in the base as shown in the photo and simulation.
Why i cant see the Ic/Ib=beta  ratio?
Thanks.
« Last Edit: November 11, 2024, 06:38:30 pm by john23 »
Online TimFox
« Reply #12 on: November 11, 2024, 06:49:06 pm »
You have applied +5 V to the collector.
At 20 mA emitter current, the voltage on the emitter is +20 V, so the base is positive with respect to the collector and emitter.
You are only seeing the base current flow into the collector, without current gain.
You say you built this:  is your graph from measurement or only simulation?
Why do you want to bias this stage with external base current instead of somehow stabilizing the emitter current?
What collector current do you want to achieve?
Why are you using a 1 k\$\Omega\$ emitter resistor?
« Last Edit: November 11, 2024, 06:51:08 pm by TimFox »
  • Country: aq
« Reply #13 on: November 12, 2024, 09:11:40 pm »
Hello,the purpose of biasing NPN threw current source is to calculate the limiting resistor needed for supplying the base of the NPN.
Why in saturation Ic/Ib is very very small?
Thanks.
Online TimFox
« Reply #14 on: November 12, 2024, 10:38:52 pm »
Why do you have that absurd 1000 ohm resistor in the emitter?
With a +5V supply, you can only get 5 mA through it:  everything else in the emitter circuit is wasted base current.
  • Country: aq
« Reply #15 on: November 13, 2024, 07:55:19 pm »
Hello , I biased my NPN to design the limiting resistor.by your  advice my maximal current should be 1000*(5/200)=25mA which is exactly the saturation current i got in the plot below.
I have made a simulation shown below by your advice where I lowered the current going into the base.
Three questions:
1.In the plot I saw the when the collector  current is saturated  Vce is very low .
Why the Vce is very low in this state?
2. suppose I have a 3V voltage source instead of  the current source.
I want to stay in linear state where Ib=45uA Ic=9mA as shown in the plot below.
How do i calculate the needed limiting resistor if I replace the curent source with 3V voltage source?
Thanks.
Online TimFox
« Reply #16 on: November 13, 2024, 08:02:36 pm »
For a BJT, "saturation" literally means that Vce is low, such that the B-C junction (normally reverse-biased) starts to forward bias.
What did you think it meant?
If you want a simple bias network for a NPN, with Ic = 9 mA, start with an emitter resistor that gives, say, +2 V at 9 mA.
Then put a voltage divider at the base that establishes the base voltage Vb (not the current) at that voltage plus Vbe = 0.7 V.
With the manufacturer's minimum value of hFE, you will get a maximum value of Ib that loads that divider;  the variation of hFE will give a variation in that Vb, which can be made small with reasonably small resistors in the voltage divider.
One should not design a bias network that depends directly on the base current for linear operation:  that is the design procedure for a switching circuit, where you establish sufficient base current to ensure saturation.
« Last Edit: November 13, 2024, 08:08:37 pm by TimFox »
Online bson
« Reply #17 on: November 14, 2024, 09:31:05 pm »
The datasheet for the zener diode will have a zener current.  At this current, and no other, will it have a 4.7V drop.  You need to size the resistor to provide this zener current, assuming a 4.7V drop over the diode.
