Author Topic: Punches for making pads for Manhattan?  (Read 583 times)
Offline 0culus
« on: September 20, 2019, 01:10:18 am »
I'm getting to the point where the projects I want to build are high speed/wideband enough that I need to be doing Manhattan style construction.
What's everyone's favorite techniques and tools for making the basic building blocks?
Offline MarkF
Re: Punches for making pads for Manhattan?
« Reply #1 on: September 20, 2019, 03:30:11 am »
Some examples from Alan Wolke:
Actually, this whole thread on the subject:
   https://www.eevblog.com/forum/beginners/copperless-perfboard-wire-wrap-for-rf-prototyping/
« Last Edit: September 20, 2019, 03:34:57 am by MarkF »
Offline ChristofferB
  • Chemistry grad student.
    • My channel:
« Reply #2 on: September 20, 2019, 06:03:49 am »
A pair of tin snips are great for cutting square islands of pcb stock. A wide bladed hobby knife (that you can put more force on than an xacto) is also a must.
Cyanoacrylate glue for sticking down dip packages and islands is a nice thing too.
I would get some sheets of thin, 0.1 or 0.2mm copper foil stock. It's pretty cheap and let's you fold little shielding boxes to put over the most sensitive parts.
--Christoffer
Check out my scientific instruments diy (GC, HPLC, NMR, etc):
Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline ledtester
« Reply #3 on: September 20, 2019, 06:34:55 am »
Offline German_EE
« Reply #4 on: September 21, 2019, 08:38:10 am »
I have the same model of punch but mine was purchased about ten years ago from Harbor Freight and then a friend brought it across the Atlantic in her luggage. It makes good clean pads even now but you have to modify one side of the die to get rid of the locating bump or your pads will not be flat.
As for the CA glue, this is what Dollar stores and Euro stores are for, that way a tube that hardens overnight will not be too much of a financial burden.
Warren Buffett
Offline ledtester
« Reply #5 on: September 21, 2019, 08:55:54 am »
Indeed, I got mine at Harbor Freight around that time, too. It's interesting that they don't seem to sell it any longer.
Offline imo
« Reply #6 on: September 21, 2019, 10:02:05 am »
Put the tube into a small plastic zip bag, add silicagel balls.
