Author Topic: Noritake VFD  (Read 2160 times)
Offline mojoeTopic starter
Noritake VFD
« on: April 02, 2016, 03:03:39 am »
Can anyone identify the microcontroller in the linked picture? It is on a Noritake VFD. Is there a particular microcontroller that Noritake commonly uses?
I tried attaching the image, but it is too big. I want to keep the detail, thus the Dropbox link.
https://dl.dropboxusercontent.com/u/19599147/CPU.png
Offline jeremy
Re: Noritake VFD
« Reply #1 on: April 02, 2016, 03:51:14 am »
Given that noritake is an OEM, a Japanese company and produces premium spec displays, my guess is that it is an asic. Why are you trying to find out?
Pretty sure my other noritake displays have asics
Re: Noritake VFD
« Reply #2 on: April 02, 2016, 04:12:06 am »
I'm just trying to reverse engineer a display. I have the parallel inputs, but there are indications that there may also be a serial input.
Offline BloodyCactus
    • Kråketær
Re: Noritake VFD
« Reply #3 on: April 04, 2016, 01:21:54 pm »
I thought all noritake displays were serial input? every one I've poked at was just a uart connection sending plain ascii. some char range were control for chaning the upper 128 ascii to japanese from old dos style...
-- Aussie living in the USA --
Offline macboy
Re: Noritake VFD
« Reply #4 on: April 05, 2016, 03:11:21 pm »
What is the exact part number of the display? Most support serial (either async or sync or both), some parallel (68k/intel/both), some both. Often there will be an un-populated header and jumpers on the board which might be used for the other interface. Try finding a data sheet for a similar display with the desired interface, then look for evidence of that on your board.
Re: Noritake VFD
« Reply #5 on: April 05, 2016, 09:01:43 pm »
I've already done all of the above. No datasheet matches this display, which appears to be custom.
