Author Topic: know where to get cheap transformers  (Read 1653 times)
Offline nusTopic starter
« on: October 12, 2018, 05:27:14 pm »
Was looking at building a linear power supply. Cant seem find 36v 5a one under $100 aud. Was thinking about just buying a linear power supply and pulling the transformer out of it. Does any one know where i could get one under tge 70 odd this cost
https://m.ebay.com.au/itm/Variable-Adjustable-Power-Supply-Linear-Mode-30V-5A-Fan-cooling-Electronic-Test/152491756214?hash=item2381378ab6:g:7ZoAAOSwCU1Y3bPA
Online xavier60
Re: know where to get cheap transformers
« Reply #1 on: October 12, 2018, 07:14:07 pm »
I was looking for a transformer recently for a power supply project.
 element14 have a large range at reasonable prices, https://au.element14.com/c/transformers/toroidal-power-transformers
« Last Edit: October 13, 2018, 05:54:56 am by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline chris_leyson
  • Country: wales
« Reply #3 on: October 12, 2018, 10:53:14 pm »
Old unwanted uninteruptable power supplies, people don't seem to change the batteries when they die they just buy another UPS sometimes because it's cheaper.
Offline mrpackethead
  • D Size Cell
« Reply #4 on: October 12, 2018, 11:15:59 pm »
Its almost a relic of the past, transformers.. :-(
Offline station240
« Reply #5 on: October 13, 2018, 12:16:04 am »
If it helps, I've got a 300VA toroidal transformer with following specs, you can have for $50 plus postage.
Two independent windings of: 28V (RMS) 5.3A
Primary fuse 3A slowblow
Consider it New Old Stock, was for a project I did long ago, got almost no use.
Comes with the mounting hardware, just need a 7mm bolt/nut to fix it.
Offline nctnico
« Reply #6 on: October 13, 2018, 12:23:14 am »
How about using a switching power supply to get to a lower DC voltage and then post regulate with the linear section. A common mode filter with some capacitors will do wonders for the electrical noise from the switching PSU.
Online xavier60
« Reply #7 on: October 13, 2018, 07:47:10 am »
That's what I ended up doing instead of buying a big heavy toroidal transformer for my bench supply project. The SMPS maintains 3v across the post reg MOSFET so even at 20 amps , the dissipation is easily managed.
The large amount of exposed high voltage circuitry is a bother.
The following users thanked this post: exe
Offline drussell
  • Hardcore Geek
« Reply #8 on: October 13, 2018, 09:42:45 am »
Standard stacked laminated transformers in that range (175-200 VA) from a good manufacturer like a Triad or Hammond should be available in the $50 range.  A torroid for about $10-15 more.
Are they really double the Canadian price down under?
Digikey Canada - ~36V transformers
I would generally prefer a good, conservatively rated (and essentially overbuilt) unit from a manufacturer like that rather than the cheap Chinesium that is usually in finished products like cheap Chinese power supplies or small UPS intended for only a few minutes run-time unless you de-rate appropriately for your design.
