Author Topic: Questions about LM2596 Buck Converter  (Read 960 times)
Offline ElectricPowerTopic starter
  • Country: no
  • I have many opinions but have no idea
    • Turer, fjas & slabberas
« on: November 20, 2019, 06:16:23 am »
1. I have read that its possible to add heat sink to LM2596 to make it give som more current output. Is this a simple task to do? If yes...how? :)
2. I have an power adapter from an old laptop that gives 20V and 4.2amp. Can i safely connect it to LM2596? I know that max theoretical output still is 3amp (theoretical) but can i use that adapter anyway?
Offline wraper
  • Country: lv
Re: Questions about LM2596 Buck Converter
« Reply #1 on: November 20, 2019, 06:57:01 am »
Are you talking about very cheap fake LM2596 modules from China?
  • Country: no
« Reply #2 on: November 20, 2019, 06:58:43 am »
I think so... ibought it frem AliExpress. It is an LM2596S (with LED display). I think it cost me 1.20$.
It is this one i ordered:
https://www.aliexpress.com/item/32825777330.html?spm=a2g0s.9042311.0.0.3fe34c4dQxQQSZ
« Last Edit: November 20, 2019, 07:02:29 am by ElectricPower »
Offline wraper
  • Country: lv
« Reply #3 on: November 20, 2019, 07:25:06 am »
Then it has nothing to do with real LM2596. They work at much lower frequency and actual specifications are not known.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: November 20, 2019, 07:27:10 am »
Try it. If it blows, you're out a buck and a counterfeit chip. ;D
Seven Transistor Labs, LLC
  • Country: no
« Reply #5 on: November 20, 2019, 07:47:55 am »
I see.
But generally... can i connect a power adapter with 20v. and 4 amps as input til this converter? I suppose it's okey as long i do not uses that power in the other end?
