Here's an example of the sort of thing i'm talking about.
https://www.digikey.com/en/products/detail/on-semiconductor/FDMT80040DC/7356044
420A continuous 2644A peak
Power dissipation 156W
But it's in a tiny 8x8mm package.
It gives some pcb layout pad size info in the DS but still, seems a little crazy.
I suspect it's intended for like 1U or 2U servers with crazy amounts of airflow.
That is very impressive indeed, but be careful with the numbers you find on the first page of the datasheet.
While it might be possible to put 400A continuously trough it doing so according to the resistance of say 0.8 mOhm (Add a bit for drop due to channel saturation, temp rise etc) you end up dissipating about 130W of heat so if you cool it from the bottom to 25°C it experiences a drop of 0.8 °C/W so the die ends up at about 130°C. It is really a best case possible laboratory scenario. To achieve this they likely soldered the mosfet directly to a fist sized block of copper that is used for both cooling and current transfer. If we assume this copper to be about 1cm around the transistor this gives an additional 0.26 °C/W. So due to the thermal resistance of the copper and extra resistive losses in the connection, this adds another 40°C temp rise, so to get the actual transistor to 25°C the outside of the block needs to be cooled to -15°C. They likely did this by forcefully pushing boiling refrigerant through cooling channels in that copper block.
Safe to say you will not be able to recreate anywhere near such conditions in the actual product. However, the engineers do end up including real world achievable thermal resistance numbers and sneaking it past the marketing department into the datasheet. The actual real world numbers for thicker copper 2oz PCB with lots of airflow is 26°C/W or 38°C/W with no forced airflow. So punching in the numbers for a reasonable 75°C ambient you get a power dissipation of 2W before the transistor blows up and this lets it pass about 50A max. However, this is still assuming your copper traces are an electrical superconductor, so on an actual 2oz PCB the traces will add additional heating and make it blow up even sooner.
If you add heatsinking you can bring the thermal resistance down to 9°C so this gets you 8W of thermal dissipation and so a max current of about 100A. If you have a good aluminium core board you might be able to push it up to 15W of dissipation so about 140A. So even the best case real-world scenario is not even close to 400, but is still very impressive for such a little mosfet.
You can parallel mosfets when in switching applications reasonably safely, just make sure they see the same resistance both thermally and electrically so that they share nicely.
