Author Topic: Quiz What is this and can it be scaled up....  (Read 2127 times)
Online tautechTopic starter
« on: November 14, 2018, 01:31:50 am »
Can I use this scaled up......and what do you think it's for ?
What will I scale it to do ?
Clues if required will be offered later.
First pic in a little custom tool project and yes it's electronics related !
Online SiliconWizard
Re: Quiz What is this and can it be scaled up....
« Reply #1 on: November 14, 2018, 01:47:25 am »
Is this some kind of bimetallic ... thing?
Offline Alex Eisenhut
  • Place text here.
« Reply #2 on: November 14, 2018, 01:49:34 am »
Sure?
The following users thanked this post: thm_w, tautech, PointyOintment
Offline Wan Huang Luo
  • 顽谎骆 from the Shenzhen Market
« Reply #3 on: November 14, 2018, 01:51:10 am »
It might be used to wind a transformer or ferrite wire at high speed
Offline Mr.B
« Reply #4 on: November 14, 2018, 01:55:30 am »
I am not sure what a Bobbin Holder for fly tying would scale up to from an electronics point of view...
Offline ArthurDent
« Reply #5 on: November 14, 2018, 02:34:58 am »
I've used these....
« Reply #6 on: November 14, 2018, 04:57:02 am »
Neither did I until a little repair project came up and it seemed like scaling it up was an obvious choice.
Another better one from my fly tying kit:
Still, we have to scale it up some as the thread bobbin hasn't enough capacity.
I've used these....
Getting warm.  :)
« Reply #7 on: November 15, 2018, 02:52:29 am »
So instead of something barely 100mm long it's now ~150mm and can accommodate the smaller solder reels or in this case a big cotton bobbin:
BOM
2.5mm HT fencing wire, 1/8" copper tube, 3/8" copper ferrule and custom steel buttons for the reel to center on.
Still, what will be it's purpose ?
« Reply #8 on: November 15, 2018, 03:37:50 am »
It’s gonna be for a nanotech social blockchain IoT synergy encabulator.
« Reply #9 on: November 15, 2018, 09:19:53 am »
Close.......not !  :)
Something to do with something like this:
But what will it fit ?
Offline PointyOintment
  • ↑ I scanned my face
« Reply #10 on: March 03, 2019, 08:46:26 am »
You're winding a wind turbine generator?
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
Offline mikerj
« Reply #11 on: March 03, 2019, 09:18:54 am »
Stator for a small engine (motorcycle?) alternator?
Offline Rerouter
« Reply #12 on: March 03, 2019, 09:23:14 am »
Fishing line reel winder, seen them used to wind 1KG solder rolls onto smaller 200g ones, if you disconnect the ratchet it would work exactly as you want.
Otherwise, something as simple as this, http://www.lapsun.com/soldering-solder-wire-reel-dispenser-holder-stand-tin-management-spool-feeder_p1008.html
Have its base weighted, and just spin the piece in your hands.
As to the purpose, I'm left thinking BLDC motor coil
« Last Edit: March 03, 2019, 10:10:36 am by Rerouter »
