Author Topic: R2 function on BJT Base  (Read 1719 times)
Offline abdulbadiiTopic starter
« on: August 09, 2022, 04:14:04 am »
Anyone outright understand what actually R2 function when R1 completely rules to control the B of BJT, why still need R2 ?
Thanks before
Online Marco
Re: R2 function on BJT Base
« Reply #1 on: August 09, 2022, 04:20:09 am »
It's always part of a resistive divider to lower the base voltage. It can be a pull down resistor for a driver which can only source current.
The following users thanked this post: abdulbadii
Offline ejeffrey
« Reply #2 on: August 09, 2022, 05:21:48 am »
If all you want to do is turn the transistor on you don't need R2.  If you want to set the operating point then you do.
R1 and R2 form a voltage divider that sets the base voltage at half the supply rail. The emitter will be 0.6 V lower than the base voltage.  The collector will draw whatever current is needed to supply the emitter, assuming the base current is negligible.
Offline Whales
    • Halestrom
« Reply #3 on: August 09, 2022, 06:04:54 am »
You are correct that R1 alone could work (with some tuning), but it's fiddler.
I'm assuming the voltage at node 3 is the output of this amplifier.
If you only have R1
You have to tune R1's resistance so that the output of this amplifier (when there is no AC signal on the input) is approximately halfway between the voltage rails.  This gives your output voltage lots of space to move before it clips.
If R1 is too small then the transistor will turn on too much and output a low DC voltage, giving it little room before it clips.  Similarly if R1 is too big then the transistor will not turn on enough, so the output voltage will be near the positive rail and give your output less room to move before it clips.
Now consider that the beta/HFE of an NPN changes between each transistor, ambient temperature and the value of the resistors on the output.  There is no one value of R1 that will always work in this circuit, you would have to connect a pot to tune it for every one you make (and maybe attach a heatsink to it).
If you only have both R1 and R2
R1 and R2 divide the input voltage to be half of the supply voltage.  Your transistor's Vbc will be perhaps a few volts, so this puts the output voltage somewhere near the middle too.  Changing the beta/HFE or temperature of the transistor won't change this too much.  You could even swap it out for different models of transistor and it will still probably be tuned well enough to work.
(In reality I'd choose slightly different values for R1 and R2 and I wouldn't exactly centre the output voltage because that's not ideal for distortion in this style of common-emitter amp, but hey it's probably close enough).
« Last Edit: August 09, 2022, 06:07:43 am by Whales »
Offline Whales
    • Halestrom
« Reply #4 on: August 09, 2022, 06:08:41 am »
Hmm, this might not really be a common emitter amp.  The emitter resistor is bigger than the collector resistor.  It's a sort of hybrid between common emitter and common collector -- I suspect its gain might be less than 1?
Online Zero999
  • 0999
« Reply #5 on: August 09, 2022, 11:20:18 am »
It will also have a relatively small voltage swing.
Thanks before
It's difficult to tell from looking at that fragment. Please post the entire schematic.
« Reply #6 on: August 09, 2022, 01:00:26 pm »
a two BJTs oscillating DC wave. ~4.1V peak
« Last Edit: August 09, 2022, 10:09:47 pm by abdulbadii »
Offline David Hess
  • DavidH
« Reply #7 on: August 09, 2022, 03:07:35 pm »
That is my favorite headache inducing circuit.
R1 and R2 in this case form a voltage divider which hold the base, and by extension the emitter, at a constant voltage.  R2 could be replaced with a zener diode but there is no need for it.
Offline TimFox
« Reply #8 on: August 09, 2022, 03:59:28 pm »
R1 through R4 are the classic method for biasing a BJT to a given quiescent current.
The rest of the circuit is the interesting part.
Offline Jay_Diddy_B
« Reply #9 on: August 09, 2022, 11:42:50 pm »
I recognize this circuit. It is the same as the oscillator that was used in the Jay_Diddy_B 5-transistor ESR meter.
Link: https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/
Forum member W2AEW made a nice video about this meter:
Model
These are all the waveforms in a mess ;-)
Separated:
The oscillator is an emitter-coupled oscillator.
I have attached the model.
Regards,
Jay_Diddy_B
* emitter coupled oscillator.asc (2.17 kB - downloaded 19 times.)
Offline David Hess
  • DavidH
« Reply #10 on: August 10, 2022, 10:23:37 pm »
Tektronix used it in a few of their probe compensation output circuits.  It has the virtue of providing a 50/50 duty cycle while using only a single capacitor.
