Author Topic: Radio Direction Finding  (Read 164137 times)
Offline PA3BNXTopic starter
  • Trying to learn better programming and designing !
« on: January 04, 2012, 09:34:45 pm »
Hello to all,
I am working on a VHF Direction Finder working
on the PC soundcard  with GPS (etrex) and plotting real time
on maps.
So see the pdf file for circuits
And the zip file for other design from do2scf
Let me know what you think of it
Any comments ?
Greetings,
Lodewijk
Credo:
Home brew projects:
Build/Design  with minimum hardware
and maximal software.
Online Psi
Re: Radio Direction Finding
« Reply #1 on: January 04, 2012, 11:09:09 pm »
Nice, I've always wanted to build something like that.
Does the direction finding work equality well for signals that are meters away and signals that are a far away? (like a few km. Assuming the signal is strong enough to be received)
« Reply #2 on: January 05, 2012, 06:46:41 pm »
Hello everybody,
It works best if the antennes are positioned free and high and outdoor.
Other wise you have multipath and reflections.
You must have a minimum distance from the tx antenna array about 3 a 4 meters.
The distance can be of cource depending on power , height and annnas of transmitting station up to
20 to 50 km.
Practically speaking the optical horizon distance.
The program MyMapping.exe has also a optical horizon calculator witch can plot
range circels on the map
d=3.58 * sqr(h1 + h2)
d in km
h1 and h2 antenne heights in meters.
« Last Edit: January 05, 2012, 07:15:32 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #3 on: January 08, 2012, 05:52:19 pm »
Hello Everybody,
I did post the antenna array for the doppler
It's a alu round plane with wooden base
and 4 whips of about 50cm welding wire 3 mm
Note that the antennas are not on the edges.
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #4 on: January 09, 2012, 09:25:07 pm »
Hello Every Body,
I am also building a HF Peiler for the 80 meter amateur bands
That uses the catcontrol from a Yaesu FT817 or FT840
That reads the RSSI an switches the magloops on of with the Sense antenna.
This project is still under programming and construction
So hint and tips ?
« Last Edit: January 10, 2012, 06:26:50 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #5 on: January 10, 2012, 06:33:34 pm »
Hello All,
I put a smal picture of MyMapping.exe
My vb2005 program that works in conjuction with
my SoundDoppler.exe
Today I did some programming to get the kml file for Google-Earth okay to.
Mymapping can print on bmp, jpg or png picture maps
almost in realtime the Doppler headings with many futures for getting cross line points
and gps inputs.
It can also put optical range circels fully automatic on the maps
ans speak the bearing like TomTom when driving and fox hunting.
Greetings,
Lodewijk
Credo:
Home brew projects:
HLA-27b
  • Guest
« Reply #6 on: January 10, 2012, 06:58:46 pm »
Quite intriguing.  What do you reckon the angular resolution to be? Anything that can resolve direction within 15 degrees with a sound card is pretty impressive.
« Reply #7 on: January 10, 2012, 09:06:24 pm »
Hello Everybody,
How accurate is a doppler bearing with the soundcard.
Well that depends on free rx site and less or no reflections
So the antenna array has to be free.
Secondly the amount of antennas and the circel diameter and how well
GP antennas are grounded at there base feet to the main plate.
The antennas must be omidirectional so not on the edges of the ground plate
The soundcard accuracy depends on the samplerate of the soundcard
in software and the doppler rotation speed frequency.
The more samples you have in one revolution the more precise it is.
You can easy have 50 to 100 Taps on 500 Hz so 360/50=7 degrees already.
Dont forget the averaging in the software that increases the precision.
Remember there is many time modulation on the FM carrier.
So for 4 whipes you can get about 5 to 10 degrees precision easy if there
are no surrounding reflections.
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #8 on: January 11, 2012, 08:12:12 pm »
Hello Every Body,
Today I thought would it not be nice if I could modify the
NMEA string $GPRMC for the GPS mouse (GPS Yellow etrax)
So that it has not the GPSCompass but GPSCompass + DopplerHeading
There are many programs that can show GPS direct on a map.
So I started writing a modifying routine that
outputs also on a com port the modified $GPRMC
Example:
$GPRMC,124344,A,5157.8111,N,00534.2454,E,0.0,30.0,110112,1.1,W,A*36
So modify 30.0 compassdegrees with the doppler heading.
and then create a new CRC after the *
So my new GPS.exe program wil read and extract the $GPRMC from the
GPS mouse and modify it and send it out on the same or other comport.
So I have again a new option for my software to build in.
Are there more Visual Basic Coders on this forum ?
 :o
Greetings,
Lodewijk
Credo:
Home brew projects:
Offline sonicj
  • updata successed!
« Reply #9 on: January 12, 2012, 01:14:06 am »
neat project! my dad and his ham buddies went hunting a rogue transmitter a month or so ago. they drove around for at least a couple of nights with a yagi and spectrum analyzer before they found the culprit.  ;D
-sj
« Reply #10 on: January 13, 2012, 08:01:59 pm »
Hello All,
I worked hard in coding to get the option
of modifying the $GPRMC string working in
my GPS.exe program.
I am still not ready with the DDE link stuff.
DDE is obsolete Dynamic Data Exchange stuff but
because my SoundDoppler en GPS are written in it I have to get it working.
Of cource I also will write this option in my New SoundDopplerNet.exe
But thats not finished / working yet.
I show you here a screen dump af a very intresting and good working
VHF soft-antenna-switcher for the doppler.
That is the datong doppler circuit on two boards.
All signals is done is through 1 coax cable witch does
do the RF, DC-powersupply and Reference for switching the antennas.
Every antenna has a wide band RF amplifier and then the output is fed throug a PIN diode
to the summer.
The advantage is that now you cannot hear in a nearby reciever the commutating
antenna whips acting as reflectors and because ist softswitching
instead of hard switching you can hear less loud stations.
« Last Edit: January 13, 2012, 08:09:39 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
HLA-27b
  • Guest
« Reply #11 on: January 13, 2012, 08:14:51 pm »
Cool job
May I ask what are the pcb sizes and hole locations are you using?
I am currently working on pcb assemblies, holes, fixing arrangements etc, hence my curiosity.
« Reply #12 on: January 14, 2012, 06:19:43 pm »
Hello All,
Here I post a picture off the Input XYscoop found in SoundDoppler.exe
The upper line is not quite a sinus but a little distorted with
the SuperSimpleSoundDoppler design.
I want some hints how to improve the sinus with minimal extra parts.
and enough output to drive the soundcard line input.
I know my software only detects the zerocrosses to get the frequency and antenna 1 position.
But it looks not nice.
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #13 on: January 14, 2012, 06:23:10 pm »
Hello All,
The PCB sizes of the datong antenna switch are about 10 bij 10 cm
They are put above each other and connected through wit some wires.
I have not made the PCB myself I did have bought some years ago
Just the Prints.
Greetings,
Lodewijk
Credo:
Home brew projects:
HLA-27b
  • Guest
« Reply #14 on: January 15, 2012, 02:56:22 am »
Just the Prints.
Thank you, 10cm X 10cm seems to be very popular naturally.
« Reply #15 on: January 18, 2012, 07:57:43 pm »
Hello Every Body,
Still working on my updated GPS112.exe program with
modified $GPRMC output through another or the same comport as where
the GPS-mouse is connected.
It takes more time than I thought.
Here is a picture of my Datong Doppler with additional
Lowpass filter on the clock for the reference of SoundDoppler.exe
(pin 12 of the 4060 chip)
This option is nice because I have the hardware 16 led display
and a connection to the pc through the SoundCardInput.
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #16 on: January 19, 2012, 07:05:21 pm »
Hello Every Body
Here I show you pictures of
a datong antenna-switcher-unit with the
ne555 power supply print
and the 4 dipoles.
« Last Edit: January 21, 2012, 06:52:53 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #17 on: January 22, 2012, 06:57:56 pm »
Hello Everybody,
I send the antenna switcher circuit in PDF of the datong doppler.
It has only one coax to the switcher unit only with the RF, Power and Reference tone.
Can some body make improvements ?
Today I worked on a new function in the InputXY scoop in my SoundDoppler.exe
So it can adjust and line up the green and yellow vertical line op on
two adjacent zero crossings from the reference (upper left channel) if you
press the middle button of the mouse or mouse wheel.
Further I am doing more modified $GPRMC string manipulations out  in GPS112.exe
So still a lot of work to do...
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #18 on: January 30, 2012, 06:52:55 pm »
Hello Every Body,
I show you a picture of my gps112.exe program
witch can send out the $GPRMC out modified with
gpscompass + doppler heading
It has also a seperate Terminal Out screen
I did already got test reports from people who have it working with
other mapping route programs.
If you click on the latitude or longitude labels
it switches between decimal degrees(Yellow) and degrees and minutes (white)
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #19 on: February 03, 2012, 07:53:21 pm »
Hello Every Body,
I hope the new SoundDoppler119 Gsp112 and MyMapping129
is soon on the site of:
http://www.pi4wag.nl/index.php/pseudo-doppler-radio-direction-finder
GPS112.exe has Terminal Input and Terminal Output screens
with freeze option.
And all the options of what to send from com1 to com2
with Modified $GPRMC for other map plotting programs.
You can also input gps from gps with mixed Agrelo %bbb/q
and then output  that through Modified $GPRMC to all kind of mapping programs.
Remark Modified $GPRMC means:
The GspCompass value is changed in GpsCompass + Doppler heading
And a new CRC is calculated in the standard $GPRMC string
So if you have a Pico Dopp RDF or a VRZA2011 RDF
You get many options.
Mymapping129.exe has also this possibility
Mymapping has complete GPS  decoding routines
And can send out Modified $GPRMC from GPS  and agrelo mixed.
So enjoy
Greetings,
Lodewijk
Credo:
Home brew projects:
HLA-27b
  • Guest
« Reply #20 on: February 03, 2012, 08:36:54 pm »
Beautiful work, and good job on the web site too.
Now that the hard work is done I hope folks start building some of their own. Maybe even I could try my hand on it!
« Reply #21 on: February 05, 2012, 07:48:37 pm »
Hello all out there,
I found a nice looking chip for the doppler switcher units
Take a look at :
http://search.digikey.com/us/en/products/AS204-80LF/863-1008-1-ND/2052163
Greetings,
Lodewijk
Credo:
Home brew projects:
« Reply #22 on: February 11, 2012, 06:59:37 pm »
Hello Every Body,
I found a nice antenna for experimenting from SM0VPO for the
Super Simple Sound Doppler Doppler.
It looks okay and very small but i di not now the bandwidth
but I think it is usable for a VHF DSP SoundDoppler.
Greetings,
Lodewijk
Credo:
Home brew projects:
Offline sacherjj
« Reply #23 on: February 12, 2012, 03:19:55 am »
I was looking at one of these a while back.  I believe there was a QRP article on it.  It linked to a Ramsey kit.  http://www.ramseyelectronics.com/downloads/manuals/DDF1.pdf   I believe this was by WA2EBY.
Using the sound card to do the dopper is a cool twist.
« Reply #24 on: February 12, 2012, 06:41:35 pm »
Hello Every Body,
Okay I know it's easy to adapt a conventional
doppler like the Ramsy  DDF1 to make it
works also together with my Sound Doppler Software.
You just connect a low pass filter  on one of the
antenna switcher outputs and make a sinus from it
at the rotation frequency from the doppler.
If you do this then it's nice too have an independent
16 led pelorus readout  and the readout on the PC..
with maps etc.
« Last Edit: February 22, 2012, 05:57:29 pm by PA3BNX »
Greetings,
Lodewijk
Credo:
Home brew projects:
