Hi Lodewijk,
first of all cudos und big thanks for your software and work you put into. With help of this software we are enabled to narrow down some qrm on local repeaters.
Using primary this software and setup in a mobile configuration we experianced some issues, which would be cool to have within the software.
1) i identified, that selectivity in notebooks sound cards are pretty poor. especially on weak signals the trigger sinus wave is recognized also on the other channel. This produces wrong bearings to sort out. A big help would be being able to select two soundcards (one for rig audio and another the trigger) or having both on one channel (checkbox selection would be fine)
2) often craft builders are not capable to differ beween clock counter wise and reverse
. A checkbox regarding that would be also very handy
3) wavelog creation is something fine, but its hard to relate them to postion and time. Therefor a general log with dde current gps, currently save wav filename and datetime would be a cool thing. If this would be a peramanent log with adding data always at the last would be perfect. This helps to analysis data afterwards
4) some replay feature would be cool, especially playing with some parameters could bring out more results
so i hope
big wishes, but all generated from practical usecases
if i can give you a helping hand on coding vb please le me know. to contribute and not just taking from the project would be highly appreciated by me.
pse drop me a line if you like.
thanks again for the software, 73 de oe6rke, ciao Robert
