So I'm not sure exactly how common it is, and I try to avoid learning any more than I have to, but we have a few systems, a chilled water system and a air handling system that has some VFDs. In manual mode I can set the VFD to whatever frequency I want, but the way the system is programmed overall it actually runs at a few speeds. For instance, 90% of the time the circulation pumps for the chilled water loop run at 30 Hz, but under some conditions it will bump up to 60 Hz. It's also possible (likely actually) that our systems were programmed by idiots, so maybe this isn't normal, but it can happen.
