Hi Again.
There always people out there to help you.
Post the nearest city to you on the forum, and maybe someone can point you to a local fabricator/engineer.
I started off at ~ age 10, dumpster diving at radio repair shops to get parts, then you get to know the guys at the repair shop, (they used to put the good stuff in a cardboard box ina corner of the dumpster where I would find it!) , and they'll give you all sorts of broken stuff to examine / dissassemble, and there are a lot of guys out there with sheds full of perfectly good through hole and leaded parts that are just not needed any more.
Try to find a local ham operator, most areas have "hamfests" or equivalent, it's a yearly bazaar of electronic cornucopia.
My first multimeter (48years ago!!) was a tiny 20kohm/volt moving needle meter. My first power supply was a tri-ang model railway controller with a big rheostat. My first transistor was a BC108, (metal can style) it arrived in its own brown paper bag, cost me $1 (about 2months pocket money) and I picked it up at another local radio repair shop, and made great friends with the technician there.
For your first assembly efforts you should be using veroboard (stripboard) this teaches you some good layout skills, being constrained to work in one direction. So all the copper goes east west, and all your links go north south. The double row TDAxxx don't fit very well on veroboard, unfortunately.
As to your design efforts ,
It looks like you are using a single sided PCB, autorouters will turn these into a bowl of spaghetti. Anyway, follow the guide below and you will improve your circuit immensely
(a) Looking at your schematic , C6 c7 c8 c9 actually have the positive the wrong way around on the schematic, so these may actually be the right way around on the PCB.
(b) Determine which way the "grain" of the schematic runs, in you case it's horizontal and runs left to right. Rearrange the parts on the schematic so they are not all tangled , and you have done this.
(bb) check your grid is set to 0.050" (or 0.025") with visible grid of 0.100"
(c) note which are the "bus" signals, e.g. +12 and gnd and the two nets running across the top. The bus signals will go all over the place and be the hardest to route, Generally you would run the gnds below all the IC's and the +12v above them. This also means that in general , capacitors will have the positive facing up.
(d) put all the parts on the blank PCB in roughly the same position as they are on the schematic , i.e so J2 on the left ; U3 in the middle , U1, U2 on the right , move J2 to the right, next to the power amps.
(e) align the parts (i.e. spin them around) so that pin 1 of U3 is top left (i.e. notch to the top) , and the heatsink of U1/U2 faces outwards (this should put pin 1 at the top??)
(f) Parts with gnd at one end should initially be aligned north south with gnd at the bottom, parts that connect to a pin should be horizontal and placed near that pin (try 0.3" away initially) like C4, C2, R1R6C3C6,C7,C8,C9 , this should give you a neat row of parts either side of U1. R3 will probably be up the top, above the notch
(g) turn on the rats nest mode, grab a part and wiggle it around to see which position gives nice horizontal lines, align all the parts neatly so that the rats nest are straightest over all. and all the parts are on the 0.100" grid
(h) double check the pots, make sure they are grouped sensibly and you can get a screwdriver to them.
(i) Now lay down a thick ground track (100 mil) as a straight line from left to right about 1" below U3 . Laydown a thickish (50mil) track for +12 from left to right about an inch above U3. You can attach one or two parts to these buses, but don't do the rest just yet, but keep thinking how are you going to get tracks to them later.
(j) You will have a bunch of easy connections- don't do them yet! Find the nets with multiple connections these are more difficult , the nets of pins 1, 6, 7 of U3 will be most difficult , so start partial track laying with these. At this point it should be obvious which parts need moving around, fix them.
(k) as a single sided board you will want to be laying tracks on the bottom layer, and these should be predominately horizontal.
(l) when you need to go vertical (ie to bridge over some tracks) swap to top layer, go vertically an integral number of grid units (0.1") and pop back again . You will need to drill the vias and place links at these positions. You can also use horizontal links (but vertical ones are most useful).
I'll repeat that - most of your tracks go east west , the remainder on the "other side" go north south , you can route ANY board using this algorithm.
(m) when you have done all the hard ones, go back and fill in the easy ones, and rearrange the power buses a bit.
(n) when finished review the whole layout, you will find a few places where you can remove the top layer links and use a more convoluted track. Try to avoid using a link to join a ground that splits it into two subnets
(o) at this point double check things like capacitor polarity. and the power pins to all IC's.
(z) Don't forget a mounting hole in each corner , put these on a sensible grid like 1.500"inches or 50.000mm , allow a big enough space around screwhole to get the screw head in.
And you are done!
