Author Topic: IC Datasheet  (Read 1685 times)
Offline ElectricGuyTopic starter
  • Country: pt
IC Datasheet
« on: March 16, 2015, 02:00:49 pm »
Hi;
I've been searching for the IC on the photo, but i'm not having success. Does someone knows where to find it?
Its from a VFD display board. This board works differently from the usually boards. Its custom made.
Thank you!
Thank you!
Regards
ElectricGuy
Offline amyk
Re: IC Datasheet
« Reply #1 on: March 16, 2015, 03:07:08 pm »
Rockwell 10937P
Now made by Micrel as the MIC10937.
  • Country: pt
Re: IC Datasheet
« Reply #2 on: March 16, 2015, 07:28:02 pm »
Rockwell 10937P
Thank you amyk.
Thank you!
Regards
ElectricGuy
