So I ran the PS charging 3.4v @15 amps and the diode gets HOT! I measured 93 Celsius before I shut it down, now rethinking the diode thing or perhaps I need to add a heat sink (if there is one in this package?)
Its weird that there isn't a normally open relay or something to interrupt the supply if power is lost, rather than use a diode.
