Hi Guys,
I'm doing a modular electronic load design and I need help with choosing a good shunt resistor. I need the shunt to handle 10A and I would like to have at least 100mV of sensing voltage, so that makes a 0.01 Ohm resistor. The module would be quite small and the heatsink would only need to dissipate 50W max, but still the PCB will heat up. So I'm looking for a high temperature stability resistors. The best ones I can find in Mouser of Farnell are 3W SMD are 50ppm/C, which seems quite high, as I'll be using a reference voltage that has 8ppm/C. Anyone has any recommendations?
Regards,
Ivo
