and often the fluid or gas its controlling is plenty hot, its located in a bad area, and its expenisve despite being small. I bet its actually not that uncommon for super expensive parts, if you need... somewhat reliable control for slightly salty water or something like that. 5% calcium chloride @ 90C , or maybe fluorine gas, abrasive liquid, hot abrasive liquid, etc. Or hot gasses might be driving a tiny valve to 95% of its thermal capacity without the power being turned on at all. Chemical engineer shit is basically rigged to blow within design specifications.
and things like it getting hit with a plume of errant steam when they open something or another (not designed for)
Keeping power low is always a good idea
